Couple of questions on the RG421 - Jemsite
post #1 of 9 (permalink) Old 04-14-2003, 05:39 PM Thread Starter
Couple of questions for RG421 owners. I've had mine now for a couple of weeks and I really do like it. I have a couple of gripes and I'm wondering if anybody can help me out.
I prefer to play 10's on my guitars so as soon as I received the guitar, I took off the 9's and put on 10's. I don't know if it's the gauge of the string but this guitar buzzes a lot. I have set the neck relief so there is virtually no bow and have set the action according to Ibanez specs at 2.0 mm on the low E and 1.5 mm on the high E. I'm still getting some buzzing on some of the lower frets and then again around 12-14 on the wound strings. On my guitar, it also seems that the nut is too high. I don't know if this could cause any buzzing or not but it is higher than any guitar I have ever played before. I almost feel like it needs to be replaced.
Thoughts, help or advice would be greatly appreciated.
Thanks
DKnight is offline
post #2 of 9 (permalink) Old 04-14-2003, 05:42 PM
With the heavier strings, you might actually try having a slight relief in the neck. As for the nut being too high, that's probably not the cause of the vibration. If it were too low, it'd definitely be suspect.
Just try adjusting the individual saddle heights until your buzzing is gone It's a trial and error process sometimes.
vaijem777 is offline
post #3 of 9 (permalink) Old 04-14-2003, 05:43 PM
site founder 0% owner
jemsite's Avatar
yup, add bow then adjust individual saddle height. the playability and tone will be much improved ...glen
jemsite is offline
post #4 of 9 (permalink) Old 04-14-2003, 05:51 PM
Ibanez setup spec calls for .3-.5mm of neck relief measured at the 8th.
Rich is offline
post #5 of 9 (permalink) Old 04-14-2003, 06:55 PM Thread Starter
Thanks for the tips guys.
Is that neck relief measured while pressing the 1st fret and the fret where the neck comes into the body, or is it measured with open strings?
Been a few years removed from setting up my guitars so I'm learning again!
DKnight is offline
post #6 of 9 (permalink) Old 04-14-2003, 06:59 PM
Fretted at the first and the last. Since I won't go near a capo I use a little bar clamp
Rich is offline
post #7 of 9 (permalink) Old 04-14-2003, 07:29 PM
Won't go near a capo?
Phobia?
Have no real need to use one (On trem equipped guitars, of course not.), other than for setup, and you have a clamp for that anyway?
Some other bizarre reason? LOL J/K
Mic
MicJustMic is offline
post #8 of 9 (permalink) Old 04-14-2003, 07:41 PM
Just never saw the point of barring a fret with one to make a chord you'd play at the nut into the same chord a couple frets higher. Got fingers to do that!
Rich is offline
post #9 of 9 (permalink) Old 04-15-2003, 10:52 AM
I agree it's a bit of a cheater, but a $3 capo is nice to have for setups.
Of course, you have a clamp for that already, so don't waste the $3.
Mic
equipped guitar , neck relief , wound strings
Similar Searches
what couple with x2n
rg421 korea?
Couple questions linuxpenguin All Other Guitars (including Prestige) 3 08-13-2011 11:04 AM
Couple of questions on RGA 121 NTF dabbler121 All Other Guitars (including Prestige) 1 05-05-2009 07:49 AM
A Couple Questions Bookshelf All Other Guitars (including Prestige) 16 11-19-2006 06:40 PM
RG 570 CT - A Couple Of Questions CrossingStar All Other Guitars (including Prestige) 1 06-25-2002 10:55 PM
New rg421 questions Noodles All Other Guitars (including Prestige) 20 09-05-2001 09:47 PM
