A Couple Of Universe Trem Problems - Jemsite
post #1 of 6 (permalink) Old 11-11-2002, 07:21 AM Thread Starter
I've got a 2000 UV777PBK and when I pull back or up to make the strings go sharp some of the strings fret-out or, that is to say, the strings touch the frets and just kind of 'clank', and the note stops. I know that will happen eventually if you pull up far enough but it happens way too early on this guitar. What could be causing it?
Also, the thing will not return to zero. This might be a question for Rich, was 2000 a year in which the posts were bad, as far as the pivot point? Which is why they came out with the new posts? I suppose I should just buy some new ones...
CrossingStar is offline
post #2 of 6 (permalink) Old 11-11-2002, 10:16 AM
as far as i know,
the strings touch the frets when the action is too low, and when the saddles are moved too backward. the more backward they're placed, the more range they'll run when you push/pull the bar.
as for the posts, wait for Rich.
nuno is offline
post #3 of 6 (permalink) Old 11-11-2002, 10:05 PM
That year (by rich's word at least) was prone to having dull knife edges. As far as the action how low is it???
sniperfrommars1 is offline
post #4 of 6 (permalink) Old 11-11-2002, 10:33 PM Thread Starter
I haven't measured it but it feels the same if not a bit higher than my other Edge equipped Ibanez' guits.
post #5 of 6 (permalink) Old 11-11-2002, 10:49 PM
what about your trem angle?
Dylan7620 is offline
post #6 of 6 (permalink) Old 11-12-2002, 05:35 PM Thread Starter
I figured out what was making the notes stop dead : the pole pieces on the bridge pickup were too high and when I'd pull up they'd hit them. Duh. Still won't return to zero, so I'll have to order some new posts.
bridge pickup
Various Trem Problems Robyn Ibanez JEM, UV, JS & Other Signature Models 1 07-02-2009 10:17 PM
Trem Problems Once Again theapprentice Tech: Setup, Repairs and Mods 8 05-09-2008 01:20 PM
Help....Universe problems. rtgibson Tech: Setup, Repairs and Mods 2 02-24-2005 08:36 AM
Jem Trem problems BigBazz Tech: Setup, Repairs and Mods 3 01-26-2005 12:09 AM
Is it safe to drill a couple of holes in the trem block? caprile Tech: Setup, Repairs and Mods 5 09-26-2003 03:28 AM
