Crack in neck? - Jemsite
post #1 of 9 (permalink) Old 04-21-2005, 11:16 AM Thread Starter
Crack in neck?
Hi- I have an oppurtunity to buy a Jem -all black,white pups,pyramids.There is a 1 1/2" verticle hairline crack on the neck-it runs between the 2 locking nut bolts.Is this common?-Does it need to be repaired? I'm getting a reduced price,but if it is trouble,I don't want it.Thanks
larrym is offline
post #2 of 9 (permalink) Old 04-21-2005, 01:06 PM
Re: Crack in neck?
It is pretty common.
http://www.ibanezrules.com/tech/setup/crack_neck.htm
What it does to the value of the guitar, I don't know.
Ferrous Lepidoptera is offline
post #3 of 9 (permalink) Old 04-21-2005, 01:26 PM
Re: Crack in neck?
I dropped my guitar a few months ago and the neck cracked exactly like on the pics. I did the repair like on IbanezRules and I can't almost see the crack anymore!
Before:
After:
krizz is offline
post #4 of 9 (permalink) Old 04-21-2005, 04:39 PM Thread Starter
Re: Crack in neck?
Thanks-The crack is nowhere as bad as yours Krizz-its just a line that runs down the neck-The guitar is still playable.
larrym is offline
post #5 of 9 (permalink) Old 04-21-2005, 04:56 PM
Re: Crack in neck?
dang!! I would panic if my neck cracked like that. Good job on the repair tho.
btangel is offline
post #6 of 9 (permalink) Old 04-21-2005, 05:43 PM
Re: Crack in neck?
Yeah, I did panic when a guitar I had got a neck crack like that. Turned out alright though. You can still see the crack where it was glued, but you can't feel it.
post #7 of 9 (permalink) Old 04-23-2005, 08:52 AM
Re: Crack in neck?
Thanks.
I happened to see the repair tutorial before so I did not panic, I was a little anxious in the beginning to do such a repair but it worked out very nice.
The only problem was that the back of the neck seemed to have been lacqued (is that the right word??) and to finish the crack I had to sand it a bit to make it more or less invisible. I was afraid that I had to sand the whole neck because only thing I had was blanc furniture oil; so I tried it on a small spot first and it worked out great! You can only _feel_ the difference between the lacqued area and the oiled spot. My first 'luthier' experience
krizz is offline
post #8 of 9 (permalink) Old 04-25-2005, 09:47 PM
Reviews: 120
Re: Crack in neck?
Same happened to mine, I couldn't bring myself to fix it though as I'm too heavy handed. Had a luthier do it and you can still see where the crack was (was so bad it had to be pinned too). But it finished up just as smooth and playing wise is no different.
LonePhantom is offline
post #9 of 9 (permalink) Old 09-30-2015, 02:49 PM
Same crack experience guys,, but luthier used super glue, its strong but the crack shows, i tried sanding it but still is there,, what can i use the cover the crack lines?marker ?, pen? I have a white jem ebony !!
stathis169 is offline
locking nut
Crack in the neck... _MKK_ Tech: Setup, Repairs and Mods 35 05-01-2007 04:57 AM
Jem 555 Neck Crack! Cobra Tech: Setup, Repairs and Mods 5 11-30-2005 07:42 AM
Stress crack on neck joint, or just a finish crack? m0p Tech: Setup, Repairs and Mods 6 11-09-2005 06:59 PM
Jem Neck Crack baldielocks Ibanez JEM, UV, JS & Other Signature Models 2 11-16-2004 02:45 PM
Neck crack on a 550 slug Tech: Setup, Repairs and Mods 4 03-13-2002 09:30 AM
