Crack and tilted trem posts - Jemsite
post #1 of 9 (permalink) Old 02-08-2004, 06:44 AM Thread Starter
A couple of years ago I noticed the trem post anchors on my UV was getting looser and I took it to a tech. He fixed it by filling the holes with epoxy (I think). Unfortunately, after a while the trem posts got tilted. And now I've noticed a crack in the body.
Is this possible to fix?
Here are a few pictures to show what I mean:
Jyda is offline
post #2 of 9 (permalink) Old 02-08-2004, 09:31 AM
site founder 0% owner
jemsite's Avatar
that is bad obviously, as the body is cracked at a bad spot. are the studs stable now, but just tilted? or loose & wobbly?
you'll need to see a competant tech and determine how this can be repaired. i'd probably consider drilling the body to stop the crack the fill with epoxy and possibly a fiber wrap. it's tough to say w/ just pictures but it should be fixable... if enough steps are taken and the crack is in a good spot regarding asthetics where you don't need to mask the fix. good luck... glen
jemsite is offline
post #3 of 9 (permalink) Old 02-08-2004, 01:29 PM
OUCH !!! I'll second what Glen has just said,get a GOOD tech to have a look, I know how i would go about it, I'd seriously think about reseating the posts on fresh wood (involves routing away a fair bit,but it'll be hidden mostly y the scrathplate), i did this on my rg/jem DPV and it was as solid if not moreso than before
I hope you get it sorted dude,
Rob
Jem7RB MK is offline
post #4 of 9 (permalink) Old 02-09-2004, 10:54 AM Thread Starter
Ok, thanks. The studs are stable now, but obviously with that tilt the trem won't return to pitch. It's odd that it could happen to this guitar as I've never gigged with it in the 10+ years I've had it.
I'll have a tech look at it when I can afford it. Guess I'll have to put away by beloved UV7PWH until then.
Thank God, I still have my other darling, a JEM7PBK.
Jyda is offline
post #5 of 9 (permalink) Old 02-11-2004, 07:56 AM
How did you do that??!!
If nothing helps, I'd seriously consider a replacement body as an option.
horstausmforst is offline
post #6 of 9 (permalink) Old 02-11-2004, 08:57 AM Thread Starter
I have no idea how it happened. As I said, it's never been gigged or really abused and is in good condition apart from this "injury". Of course, it has got a few bump marks as I've used it at home for more than 10 years, but those are just beauty marks. It may have something to do with the combination of uneven pressure from the trem post and the dry weather in the winter.
Would I have to get a custom body made or does Ibanez offer a replacement in exchange for the old one? (I just wish that was true for my own body )
Jyda is offline
post #7 of 9 (permalink) Old 02-11-2004, 10:23 AM
Ibanez MAY do a replacement in exchange and lots of cash on your part,It's dependant on your local rep/store
My choice for a NEW body is EKG the banner is up top, fantastic work :-)
Before you do go that route tho,Fire off an E-Mail to Eddie anyway and see what he says about repairing it,you may find it's not the expense you had thought
Good luck dude,And let us know how you get on
Rob
post #8 of 9 (permalink) Old 02-11-2004, 10:24 AM
I just thought,Where are you located dude?
Rob
post #9 of 9 (permalink) Old 02-11-2004, 10:46 AM Thread Starter
Rob
I'm in Sweden (updated my profile). I know of a good tech here and will have him look at it. I've seen EKG's work and it looks first class so that's definitely a possibility, but I'm rather short on cash right now.
Jyda is offline
trem posts won't go further down! straymond All Other Guitars (including Prestige) 5 11-07-2012 04:05 PM
Best Trem Posts LonePhantom Tech: Setup, Repairs and Mods 12 05-02-2008 10:52 AM
Crack in RG Trem Hole xdos All Other Guitars (including Prestige) 5 05-04-2007 10:08 AM
where can I get the trem posts for the Edge trem? rx Ibanez JEM, UV, JS & Other Signature Models 6 03-17-2005 08:24 PM
LO TRS II TREM POSTS rgtojem Tech: Setup, Repairs and Mods 8 12-04-2003 10:20 PM
