custom body floyd rose question - Jemsite
post #1 of 13 (permalink) Old 10-11-2011, 03:26 PM Thread Starter
first off, hello to everyone here! ive been a lurker for quite a while and just finally joined.
onto my question, i am building an acrylic RG body for my 7 string. i have the body almost finished, i used the original body as a reference and its exact, but i had a question about the floyd rose and its posts.
can i just drill and thread the acrylic itself or do you think i should get some metal threaded inserts to screw the posts into. and if that is the route i should go, would i call floyd rose or ibanez for the inserts?
thanks in advance!
kyle
m0rb1d is offline
post #2 of 13 (permalink) Old 10-11-2011, 09:38 PM
Re: custom body floyd rose question
I would use the inserts with the studs. A) easier to install and B) longer lasting. Plus Floyds already have the inserts with the studs so C) why not use them?
In reading back through your original post, I'm assuming you have a Floyd and it has the inserts w/studs?
TMatt142 is offline
post #3 of 13 (permalink) Old 10-11-2011, 09:57 PM Thread Starter
yes, but the studs are in the original wood rg body. is there a way to get them out without destroying the original body?
m0rb1d is offline
post #4 of 13 (permalink) Old 10-12-2011, 07:28 PM
This may mortify you but what I do is set the body on a towel, place another towel next to the studs on the face of the body (over where your pickups go), screw your studs back into the inserts, get a hammer and use the claw of the hammer to pry them out. Just go about it carefully and they should pull out without too much effort.
TMatt142 is offline
post #5 of 13 (permalink) Old 10-12-2011, 11:27 PM Thread Starter
awesome, thank you matt!
im going to try this tomorrow, ill be gentle...ish.
m0rb1d is offline
post #6 of 13 (permalink) Old 10-13-2011, 12:09 AM
Reviews: 98
Project guitar has a tutorial for removing the inserts.
AlaskaBat is offline
post #7 of 13 (permalink) Old 10-13-2011, 12:09 AM
RGTFanatic's Avatar
use a thin piece of wood between the hammer and the body...I also put painters tape on the body. Don't forget to score the paint with a sharp blade around the anchors first, or will end up looking like mine did.
RGTFanatic is offline
post #8 of 13 (permalink) Old 10-13-2011, 02:15 PM Thread Starter
Thumbs up Re: custom body floyd rose question
wow, thanks for the input guys! couldnt ask for better help!
m0rb1d is offline
post #9 of 13 (permalink) Old 10-13-2011, 07:49 PM
Where in Wisconsin are ya?
TMatt142 is offline
post #10 of 13 (permalink) Old 10-13-2011, 09:04 PM
If it is stubborn heat it up a bit with a soldering iron, that has helped me in the past
andrewgosline is offline
post #11 of 13 (permalink) Old 10-14-2011, 12:33 AM Thread Starter
i am in madison.
and thanks andrew!
you guys are the ****!
m0rb1d is offline
post #12 of 13 (permalink) Old 10-17-2011, 10:06 PM Thread Starter
they came out way easier than expected, thanks again!
ill be sure to post some pics of the body in the near future as well.
m0rb1d is offline
post #13 of 13 (permalink) Old 10-18-2011, 10:19 PM
Sweet...Glad it all worked out for ya.
TMatt142 is offline
acrylic
Floyd Rose II Question mgk321 Tech: Setup, Repairs and Mods 3 05-27-2011 02:29 AM
FS H-H Basswood Floyd Rose body Phred Classified Ads: Guitars and Gear 0 08-03-2010 09:56 AM
Floyd rose question Shredragrammaton Gear, Equipment, Recording & Off Topic 3 10-14-2009 06:33 PM
Fill Floyd Rose Special Fit My Jem body? Joe341 Tech: Setup, Repairs and Mods 3 09-16-2009 05:51 AM
Floyd Rose Question MichaelQ Tech: Setup, Repairs and Mods 5 12-30-2002 01:32 PM
