Damaged the hole surrounding my neck screw ferrule. - Jemsite
post #1 of 15 (permalink) Old 01-25-2016, 10:34 AM Thread Starter
So when I was tightening my neck screw, I realised the ferrule had cut into the wood, and damaging the wood surrounding the ferrule.
Here's the damage.
Imgur.com/a/uSs1u
The guitar still stays in tune, neck is tight, no cracks, everything is still stable and normal. Is this a damage I need to worry about? Or is it purely cosmetic. Does it call for a repair?
monolithic87 is offline
post #2 of 15 (permalink) Old 01-25-2016, 01:28 PM
Re: Damaged the hole surrounding my neck screw ferrule.
Basswood, very soft. I might run some CA, then accelerator in and around the bare wood just to seal and strengthen it, but it should be nothing to worry about.
Rich is offline
post #3 of 15 (permalink) Old 01-25-2016, 06:11 PM Thread Starter
Would this manifest itself as a problem I'm, 5 years time or so? No?
post #4 of 15 (permalink) Old 01-25-2016, 06:12 PM
It can only compress so much.
Rich is offline
post #5 of 15 (permalink) Old 01-25-2016, 06:33 PM Thread Starter
Alright then, guess I won't do anything about it then. If I do want to repair it though, what's the proper procedure to do it?
post #6 of 15 (permalink) Old 01-25-2016, 08:41 PM
Rich is offline
post #7 of 15 (permalink) Old 01-25-2016, 11:26 PM Thread Starter
As in, what can I do to fill up the wood that has been compressed? Can I do something like fill it with wood filler, or plug and redrill?
post #8 of 15 (permalink) Old 01-25-2016, 11:51 PM
I see no point in it, but you're welcome to do whatever you wish.
Rich is offline
post #9 of 15 (permalink) Old 01-26-2016, 06:13 PM
Just do as Rich says, if it really bothers you then take a sharpie or black paint pen and color in the wood indentations, then do as Rich says.
Either way, you should just do what Rich says.
aesthyrian is offline
post #10 of 15 (permalink) Old 01-26-2016, 09:41 PM Thread Starter
Yeah I have decided to just leave it be. As long as it won't affect the stability of the guitar.
post #11 of 15 (permalink) Old 01-26-2016, 09:47 PM
The crack to the neck side of it would make me want to flow CA into it to lock it all up and make it harder.
Were you using a power drill by chance?
Rich is offline
post #12 of 15 (permalink) Old 01-26-2016, 11:12 PM Thread Starter
Nope just a plain old screwdriver.
post #13 of 15 (permalink) Old 01-27-2016, 10:04 AM Thread Starter
I might be able to get CA.. Not sure which store carries it, might be quite a distance away.
But is it okay to just leave it as it is?
post #14 of 15 (permalink) Old 01-27-2016, 05:17 PM
If you wish, it's not going to fall apart.
http://www.ebay.com/sch/i.html?_from...smith&_sacat=0
That's the type you want [blue bottle, and accelerator] and is what's usually available at local hobby stores with a store brand label.
Rich is offline
post #15 of 15 (permalink) Old 01-27-2016, 11:55 PM Thread Starter
Alright I guess I will walk around and see if I can find that in local stores. If I can't I guess I will just leave it be.
Reply sustain : does the neck hole or screw right under hurts it? panix Tech: Setup, Repairs and Mods 9 08-06-2015 10:00 AM
damaged saddle/ intonation screw hole in edge zero 2 .. repair help?? :( bonsuer Tech: Setup, Repairs and Mods 8 05-05-2012 02:37 AM
Strap screw hole oversized/worn fix? jemuniverse777 Tech: Setup, Repairs and Mods 10 03-12-2011 10:51 AM
Damaged Neck Screw Holes On My Body Eddie_V_H Tech: Setup, Repairs and Mods 10 04-11-2007 03:03 AM
Filling Screw Hole in Spring Cavity Ozzdoc Tech: Setup, Repairs and Mods 10 02-25-2006 10:33 AM
