Default trem stud squeaky - Jemsite
post #1 of 9 (permalink) Old 01-08-2015, 07:05 AM Thread Starter
trem stud squeaky
Hello,
the uv70p is the only inserts/studs-equipped locking trem of my guitars. (The other two older ones have the oldest screw-pivots). Those studs are also locking, in the sense that they have a concentric minor bolt used to lock down the stud in place. So the smaller bolt (unseen by bare eye) must be untightened in order for the stud to be able to screw in clock-wise. I have noticed that when I turn the stud (clockwise or counter-clockwise), it produces a noise, a squeak, like there is friction between the stud's threads and the insert's (bushing's) threads. Is this bad? And if yes, how can it be remedied? Some wd40? Maybe grease or engine oil of some sort?
panix is offline
post #2 of 9 (permalink) Old 01-08-2015, 07:23 AM Thread Starter
Re: Default trem stud squeaky
Sorry for the word : default. Cannot see how it got its way in the subject.
panix is offline
post #3 of 9 (permalink) Old 01-08-2015, 03:36 PM
RGTFanatic's Avatar
It is probably the knife edge friction on the stud causing the noise. Used a very small dab of lip balm on the stud to lubricate the friction point.
RGTFanatic is offline
post #4 of 9 (permalink) Old 01-08-2015, 04:01 PM
pull both the floyd and trem post out of the guitar and clean them with a rag or soft tooth brush. You can put graphite or oil on the trem post / base plate contact point and then tune it up from there.
The squeak can be a few things. if that doesn't work check to make sure your floyd rests in the neutral position. If not you may need a set up. The trem springs can also squeak when you use the trem. You can add some foam underneath the springs to help dampen the noise.
j.arledge is offline
post #5 of 9 (permalink) Old 01-08-2015, 04:06 PM Thread Starter
Thanx Ryc, Will check this out. It is weird that it does this squeaking sound only on the bass side stud. The treble side stub turns with no complaints.
panix is offline
post #6 of 9 (permalink) Old 01-08-2015, 04:08 PM Thread Starter
Thanx, yes the trem plate (edge zero ii-7 string) is almost perfectly parallel to the body. For some reason, I have not eliminated the case of the threads producing that noise. As far as the springs go, this is a different chapter, I have already ordered after market noiseless springs. Anyways, although irrelevant to this thread, a mod I have done is just inserting 5mm rubber tubing (bought from medical supplies) into the springs. Almost makes them noiseless.
panix is offline
post #7 of 9 (permalink) Old 01-08-2015, 04:13 PM
RGTFanatic's Avatar
It's not really that strange if you consider that the knife edges are different shapes. I've had plenty that squeak, but never both that I remember.
post #8 of 9 (permalink) Old 01-09-2015, 02:16 AM Thread Starter
Thanx for the info Ryc!
panix is offline
post #9 of 9 (permalink) Old 01-10-2015, 01:49 PM Thread Starter
Inspected the inserts/bushings and studs today. All OK. They had some grease over there from the factory, or from the service in Germany. Can't tell. Anyway, I wiped away the excess of it, and I think the noise is minimized. All good!
panix is offline
edge zero-ii , squeaky , stud , trem
Chipping around trem stud. fwd0120 Tech: Setup, Repairs and Mods 23 07-03-2012 01:25 PM
New RG2570, Fret Buzz+Squeaky Trem krazy_korean Tech: Setup, Repairs and Mods 2 08-21-2008 03:04 PM
Help!!! Trem Stud!! bobojem Tech: Setup, Repairs and Mods 9 08-07-2005 09:33 AM
Broken LPE trem stud - getting it out! LordOfTheStance Tech: Setup, Repairs and Mods 2 04-15-2005 09:25 AM
SQUEAKY lo pro trem arn! jpwannabe Tech: Setup, Repairs and Mods 1 03-23-2004 01:50 PM
