difference between edge bridges - Jemsite
post #1 of 4 (permalink) Old 03-21-2004, 11:06 AM Thread Starter
I bought a secnd hand Edge floyd rose to swap my old rusty trem in my 777DY.
Although it should be exactly the same trem, I noticed differece between the studs, the fine tuners and the arm holder. Does Ibanez changed the design of this old trem?
jemke is offline
post #2 of 4 (permalink) Old 03-21-2004, 12:30 PM
ScottB's Avatar
Can you post some pics of the two bridges?
ScottB is offline
post #3 of 4 (permalink) Old 03-21-2004, 03:24 PM Thread Starter
The arm holder has thread on almost the whole outer surface my old trem. The arm holder on the newer trem has thread on just the part where it is attached at the tremplate.
The fine tuners have a different 'groove'. Just a minor difference.
The newer studs are smaller above the thread.
I can't post picks, because the trem is already in the guitar and I can't see the difference between the studs and arm holer anymore.
jemke is offline
post #4 of 4 (permalink) Old 03-22-2004, 03:00 AM
yes, old Edges are slightly different than the newer ones. also, the newer Edges have "locked" Fine-Tuners, that won't fall off if you over-loosen them, with a plastic washer that will keep the Fine-Tuner in place.
you can also notice the higher precision which the newer saddles are cut with, in opposite to the older ones which were slightly rough and rounded on the edges.
nuno is offline
arm holder , floyd rose
Edge 3 bridges? carbons2k Tech: Setup, Repairs and Mods 8 09-26-2009 05:11 PM
difference between fixed bridges garegin All Other Guitars (including Prestige) 10 11-26-2007 12:42 AM
Edge III Bridges LethalAe86TypeR Gear, Equipment, Recording & Off Topic 21 11-15-2006 08:22 PM
Difference between bridges Ironjose Tech: Setup, Repairs and Mods 10 07-11-2006 01:05 AM
Edge and Lo Pro Edge Bridges: Are they hardened steel? Given to Fly Tech: Setup, Repairs and Mods 2 04-12-2003 09:37 PM
