Does my Neck Need to be Shimmed? - Jemsite
post #1 of 5 (permalink) Old 01-28-2006, 02:44 PM Thread Starter
Here are the specs on my guitar:
Neck Relief - .004'' (.102mm) measured at the 9th fret
Low E action - 1/16'' (1.5875) measured at the 12th fret
High E action - 1/32'' (.7938mm) measured at the 12th fret
Gap Between 2nd fret when when holding down the 1st fret - .013'' (.330mm)
The reason I ask is because my trem is pretty far down in the cavity. When it is set up properly, it looks like this:
Right now I actually have it on more of an angle to allow for a bit more pull-up, even though it causes some slight tuning stability problems (but not much). Maybe the nut is too high? I wouldn't be surprised if it is. My strings are 10-52s and it's tuned to Eb at the moment if that makes much of a difference. The guitar plays great though and I plan on buying 2 more Ibanez guitars this year.
Code001 is offline
post #2 of 5 (permalink) Old 01-28-2006, 03:11 PM
Re: Does my Neck Need to be Shimmed?
You dont actually mention if the guitar previously had a different gauge string fitted prior to your problem, or have you suddenly started to play using 'dropped' tuning?
Both can make a lot of difference to the angle of trem, as well as intonation, relief and action.
This could be as simple as adjusting the trem springs or a little more complex procedure to set up everything else.
If in doubt, take it to your local pro.
Liggy is offline
post #3 of 5 (permalink) Old 01-28-2006, 03:55 PM Thread Starter
I do all my own setups. I set the trem up this way, along with all those specs. The trem is the same as it has been for about a year now. I just decided to ask this question now though. I'm just asking if it's normal for the trem to be this low with my specs.
Code001 is offline
post #4 of 5 (permalink) Old 01-28-2006, 04:07 PM
i think its normall specailyl being you have the low profile
honky_tonk is offline
post #5 of 5 (permalink) Old 01-28-2006, 04:52 PM
Id say definately Yes!!
The guitars i have with the Edge Pro (and lll) are set up with trem parallel to body too
Liggy is offline
ibanez guitars , neck relief , trem springs
FS: LOCAL DEAL(MPLS MN)- Lot of Ibanez RG550 parts, neck, body and Roadstar neck CrossingStar Classified Ads: Guitars and Gear 3 06-10-2011 07:24 PM
FS: RG550 Maple neck/Edge Trem, Jackson neck, Dimarzio pups NickCormier Classified Ads: Guitars and Gear 10 01-08-2010 12:46 PM
Flamed jackson neck, birdseye musikraft neck, loaded strat body shesky Classified Ads: Guitars and Gear 2 04-30-2009 06:02 PM
ok, ibanez switch H-H, pos1 = neck(hum mode) pos2 =neck(Inner Coil only) 7-request Pickups & wiring 2 07-05-2005 11:18 AM
Question for those who have shimmed their own necks Triangle Tech: Setup, Repairs and Mods 10 05-04-2002 02:03 PM
