Dumb question... - Jemsite
post #1 of 9 (permalink) Old 12-29-2005, 12:45 PM Thread Starter
Dumb question...
Is there any advantage/disadvantage to push-push pots or push-pull pots as an on/off switch? Are they pretty much the same and it's just personal preference or is one better than the other? It will be for controlling LEDs. Thanks.
Hobophobic is offline
post #2 of 9 (permalink) Old 12-29-2005, 01:11 PM
bluealien's Avatar
Re: Dumb question...
as long as the pot handels the ohms for on/off, it should be no problem, and is just preference on setup.
bluealien is offline
post #3 of 9 (permalink) Old 12-29-2005, 01:14 PM Thread Starter
I want to use my tone pot as the on/off switch for the LEDs but I didn't know if it mattered if it was push-push or push-pull. Thanks for the reply!
post #4 of 9 (permalink) Old 12-29-2005, 01:18 PM
rgr
No, is shouldn't matter. Not trying to be a smarta$$ but I have no clue what bluealein is talking about.
Roger
rgr is offline
post #5 of 9 (permalink) Old 12-29-2005, 02:53 PM Thread Starter
I'm not really sure what that meant either but, after discussing it elsewhere, I've decided to go with the push-pull. I was thinking the push-push may be a little quicker and easier to use on the fly but I've been told that the push-push type sticks out more and can get in the way because it needs extra room to do it's little "click" thing at the bottom that throws the switch. Thus it can't be mounted with the knob right against the body like a push-pull can.
post #6 of 9 (permalink) Old 12-29-2005, 03:17 PM
bluealien's Avatar
The three most basic units in electricity are voltage (V), current (I) and resistance (r). Voltage is measured in volts, current is measured in amps and resistance is measured in ohms.
post #7 of 9 (permalink) Old 12-29-2005, 05:24 PM
Still have no idea what bluealien is going on about. That has nothing to do with the question. If you are referring to the resistance for the LED circuit, that comes from a resistor, not the switch.
It doesn't matter which you use -- it is just a switch attached to a pot. Use whichever one you prefer. But as for the height issue, the push-push is probably still going to be lower than the push-pull when pulled up (or at least no worse). You might want to consider that. Pick the one you like better.
ryanb is offline
post #8 of 9 (permalink) Old 12-29-2005, 07:03 PM
rgr
Yes, you are correct, but a switch is either on (0 ohms or close) or off (infinite or very high resistance). He is looking for a switch to turn LEDs on and off, so your first statement really made no sense, nothing really "handles ohms". I don't know what his setup for the LEDs is, they will need a series resistance to limit the current for the LEDs, you can't just hook up an LED to a battery. But, a pot with a push-pull or push-push switch will work nicely if LEDs are your thing.
Roger
rgr is offline
post #9 of 9 (permalink) Old 12-29-2005, 07:27 PM
bluealien's Avatar
Heheh, I guess I was thinking he would want to create a a dim switch effect or use the pot for multi items (Volume or Tone).. sorry for the confusion
really dumb question? moosejr All Other Guitars (including Prestige) 13 08-25-2017 06:28 PM
Dumb question... shreddingjoris Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 5 02-06-2014 04:39 PM
A Dumb Amp question Slimjim Gear, Equipment, Recording & Off Topic 2 11-11-2008 05:31 PM
Another dumb question dreaming_neon_black All Other Guitars (including Prestige) 2 03-11-2005 03:47 AM
this is probably a really dumb question meegs666 Ibanez JEM, UV, JS & Other Signature Models 1 06-10-2004 12:10 PM
