Dumb question - adding 4th spring on edge block - Page 2 - Jemsite
post #16 of 18 (permalink) Old 09-09-2002, 08:50 PM
... I've had springs fly off, using Orig. Floyd Rose (so I'm sure it would happen to me with an Edge/LoPro with no block-lock) I came up with my own method to keep this from happening (posted on old forum, I think) - but prefer the Ibanez block-lock solution.
I would never use an Edge/LoPro without... unless it was older and not tapped for the screws; then I'd use my ol' Floyd Rose method.
steve is offline
post #17 of 18 (permalink) Old 09-10-2002, 03:39 AM
Ive had em fly out enough that it was a MAJOR pain in the bum. I saw it strip the block on an original floyd after popping out so much that the inertia block had to be removed and turned completely around. But Ive never seen an edge trem do it *because it has the bar * lol
sniperfrommars1 is offline
post #18 of 18 (permalink) Old 09-10-2002, 09:03 AM Thread Starter
Thanks for your help!! Umm... But I just tried another set of springs, now it's working fine, still with only 3 installed .. Oh, and I won't be using the spring lock bar anyway, cause the trem then wouldn't quite fit into my S guitar
horstausmforst is offline
edge trem , floyd rose , retainer bar , string gauges , trem block
For Trade: 31mm Edge spring block for 41mm block mtxsho93 Classified Ads: Guitars and Gear 0 04-02-2007 06:29 PM
Edge Spring Lock question LonePhantom Tech: Setup, Repairs and Mods 15 01-21-2007 02:09 AM
Adding spring reverb to an amp bduersch Gear, Equipment, Recording & Off Topic 6 07-15-2005 09:05 PM
Adding spring tension on trem... Dr Mindcrime Tech: Setup, Repairs and Mods 6 09-26-2004 01:00 PM
edge spring block lock, does it affect tuning stability satchman Tech: Setup, Repairs and Mods 5 03-03-2003 10:21 PM
