E-string too close to the fretboardedge - Jemsite
post #1 of 11 (permalink) Old 01-31-2006, 12:20 PM Thread Starter
Question E-string too close to the fretboardedge
The e-string on the bass side is very close to the edge and is prone to slide off the board if I'm not very careful when fretting. Is it possible to loosen the neck, yank it a bit to the right and fasten it again?
StTan is offline
post #2 of 11 (permalink) Old 01-31-2006, 12:29 PM
Re: E-string too close to the fretboardedge
yes bro you can do that but be careful ok!- & if that don't work see a guitar tech to find a way on how best to fix the problem, you didn't say what type of guitar?
jaken777 is offline
post #3 of 11 (permalink) Old 01-31-2006, 12:33 PM Thread Starter
It's a PGM 100.
StTan is offline
post #4 of 11 (permalink) Old 02-01-2006, 02:54 AM
My guess is that the trem isn't centered properly, I've seen that with the TRS models. Those are DAMN nice guitars too. The only thing that kept me from buying one was the trem.
Mike
TheToneZone is offline
post #5 of 11 (permalink) Old 02-01-2006, 08:44 AM
Yes could be the trem post or even the trem knife edges. I've this happen with a bent post, post threads had moved in the body and also the knife edges can move.
Ant1981 is offline
post #6 of 11 (permalink) Old 02-01-2006, 01:46 PM Thread Starter
It's an Edge and it seems to be correctly centered, at least according to the routing.
Here's some pics. Actually its not as bad as it looks at the pic. I guess it's the photoangle, but you get the idea.
StTan is offline
post #7 of 11 (permalink) Old 02-03-2006, 08:58 AM
Hi StTan
I had a similar problem with an RG550....although in my case it was the high E that was close to the fretboard edge.
I removed the neck completely, during a spring-time clean, and checked the neck pocket. Upon putting the neck back on I inserted a thin shim between the body on the bass side and the neck itself.....while I was putting the neck back in place I applied a little pressure to the edge of the neck....obviously from the bass side to the treble side in my case but opposite in yours.
This all meant that when everything was tuned up and good to go the alignment was improved ten fold. It could maybe do with a slightly thicker shim to be perfect but it play just fine and has improved it no end.
Hope this helps
Cheers
Steve
Chipiem is offline
post #8 of 11 (permalink) Old 02-03-2006, 10:54 AM
rgr
The trem looks kinda off in the pic, but it may be the angle. Yes, you can loosen the screws some, don't loosen them all the way, and shift the neck. It's a common thing to do on bolt-on guitars, an old guitar tech friend of mine showed me many moons ago.
Roger
rgr is offline
post #9 of 11 (permalink) Old 02-03-2006, 11:34 AM
Roger
Yes you can do that. The EBMM EVH model that I have is notorius for the E string slipping off the fretboard and my guitar tech did the same thing (as above) and hasn't slipped off once since it's been done............
bob mclaughlin is offline
post #10 of 11 (permalink) Old 02-04-2006, 11:13 PM
Wink Re: E-string too close to the fretboardedge
it's a neck problem looking at the pictures you posted, the neck is about 3mm out to the top horn of the guitar, just look at the pickup mounting ring to the bottom of the neck you can see how far it's out there, noway a trem problem there bro, the trem sits fine from what i can see, your lucky bro its easy to fix it! Very Nice PGM i bet it sounds good to!
Cheers- Jake.
jaken777 is offline
post #11 of 11 (permalink) Old 02-11-2006, 10:31 AM Thread Starter
Right Jake. I saw the misfit when you pointed it out. Did the 'yanking' and problem, if not totally solved, at least much better. Thanx all for the info.
StTan is offline
ebmm evh , guitar tech
Low E string too close o the edge of the fretboard Lamer Tech: Setup, Repairs and Mods 5 09-04-2010 06:37 AM
Hige E string close to edge of Neck ryanboy2004 All Other Guitars (including Prestige) 6 02-25-2010 09:32 PM
Evo 7: how close it it to Evo 6? Petie Pickups & wiring 4 02-21-2007 01:18 PM
A few of my close friends fishhead785 All Other Guitars (including Prestige) 37 02-14-2006 06:21 PM
Action close-ups of Evo and FLO pri0531 Ibanez JEM, UV, JS & Other Signature Models 16 11-12-2002 11:49 AM
