Easy Fret Bender for Dunlop Pre-Cut Fretwire - Jemsite
post #1 of 5 (permalink) Old 03-25-2013, 11:36 AM Thread Starter
Hi Folks
Found a quick and dirty fretbender for Dunlop pre-cut frets. Ran to home depot and found a 4" male pipefitters cap that worked really well. The fret fit in the thread nicely and it only cost $5.
dinobambino28 is offline
post #2 of 5 (permalink) Old 03-25-2013, 05:39 PM
Re: Easy Fret Bender for Dunlop Pre-Cut Fretwire
the reason why you bend the frets is to match the radius of the fretboard.
you could use a jig saw and cut out a circle that has a the radius and your fret board and then clamp the fret wire to the circle.
you could also just pony up the money for a stew mac fret press
either way using something with a smaller radius than you neck is going to mess up neck radius when you put the frets on the fret board.
j.arledge is offline
post #3 of 5 (permalink) Old 03-25-2013, 06:14 PM
RGTFanatic's Avatar
Originally Posted by dinobambino28 View Post
Hi Folks
This is good thinking, but J. is right that 4" diameter is way too small (2" radius). You DO want to pre-bend to a smaller radius than your fretboard, but 2" to 17" is way too extreme. you would want something at least 12" in radius (24" across).
I still like the way your thinking Dino, maybe you can find something else a little closer?
RGTFanatic is offline
post #4 of 5 (permalink) Old 03-25-2013, 07:11 PM
Reviews: 15
Cool idea, but my worry, in addition to the radius issue, is introducing a little twist in the fretwire since you're winding it around a threaded object vs. something with a singular channel.
silverctr is offline
post #5 of 5 (permalink) Old 03-26-2013, 02:40 PM Thread Starter
Thanks for your input guys. The frets actually came out pretty well. After bending on the 4" pipe they came out to about a 7" radius. Twisting wasn't an issue - they fit in that thread perfectly and lie perfectly straight on their side. A larger pipe would be better - maybe a 6" would give me a 10" radius.
Up to this point I've always overbent my frets a little (with a friend's stewmac fretbender) & hammered them in with a hammer. If I was to bend a long piece of wire I'd definitely use your method J.Arlege.
fret bender pre-cut frets
dunlop pre-cut fret wire walterh Tech: Setup, Repairs and Mods 3 05-21-2010 01:59 PM
6105 vs 6150 Dunlop fret wire 8 Big Tubes Tech: Setup, Repairs and Mods 0 11-19-2009 06:35 AM
BBE Mind Bender Pedal-New in Box nitro Classified Ads: Guitars and Gear 3 10-12-2009 09:51 PM
pitch bender plugin Jeff Gear, Equipment, Recording & Off Topic 1 04-25-2005 01:14 AM
