Edge 3 problem again - Jemsite
post #1 of 5 (permalink) Old 06-23-2011, 08:07 AM Thread Starter
Exclamation Edge 3 problem again
k guys i have a problem with my trem. I was just playing normally after i adjusted the string height a bit and use tremolo slightly, then there was a loud noise. I noticed that one of my saddles went all the way forward. Now all my strings are out of tune. what is the problem? do i just normally intonate it?
tophermathews is offline
post #2 of 5 (permalink) Old 06-23-2011, 08:59 AM
Reviews: 6
Re: Edge 3 problem again
You'll have to pull the string in question, but either the intonation screw was loose, and it pulled towards the neck, throwing the tuning off, or the screw snapped. Screws are usually available at fastener supply houses.
As well, it's possible something larger is wrong with the bridge. The only way to find out is to pull the string off and have a look.
Philboski is offline
post #3 of 5 (permalink) Old 06-23-2011, 09:09 AM Thread Starter
k then it sounds pretty complicated ill give it in to a guitar tech thanks for the help.
post #4 of 5 (permalink) Old 06-23-2011, 09:18 AM
Reviews: 6
Removing a string and looking at the screw is NOT complicated.
post #5 of 5 (permalink) Old 06-23-2011, 11:08 AM
Reviews: 11
you should really learn how to set up a floyd rose yourself. It will save you headaches and money in the long run.
As others stated, your saddle slid forward most likely because the set screw vibrated loose. When that happened the string tension on it loosened. Im guessing it was one of the thicker strings that did it. When that happens the balance on the floyd rose goes out of whack, and it pulls back. Im guessing the other strings are high out of pitch?
linuxpenguin is offline
edge 3 bridge , ibanez rg350ex
Edge Pro problem Andrimner Tech: Setup, Repairs and Mods 12 10-13-2009 03:38 PM
edge pro problem. help? DanEwins Tech: Setup, Repairs and Mods 1 03-22-2009 12:40 PM
edge 3 problem prydogga Tech: Setup, Repairs and Mods 3 01-07-2009 08:31 PM
Lo pro edge & Double Edge in tune problem Raffel Tech: Setup, Repairs and Mods 21 05-14-2004 08:59 AM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 01:43 PM
