Edge II Brass sustain block help - Jemsite
post #1 of 8 (permalink) Old 02-18-2017, 08:25 AM Thread Starter
I got a 2013 RG450 which comes equipped with an Edge II (I believe) without the zero point system. Currently trying to find a brass block replacement but all I seem to find are block that are designed for Edge II with the zps. Anyone know if a block for the original edge will fit an edge II. Any information would be greatly appreciated.
Animus is offline
post #2 of 8 (permalink) Old 02-18-2017, 12:34 PM
Re: Edge II Brass sustain block help
The bridge you have is the "Edge Zero II". I don't know if there was ever a such thing as the "Edge II", but if there was it was before my time.
The brass trem block you want is this one:
http://www.killerguitarcomponents.co...o-block-detail
Inzane is offline
post #3 of 8 (permalink) Old 02-18-2017, 07:39 PM Thread Starter
That's designed for the zero point system. Mine does't have that. If I were to use that block I wouldn't be able to mount my spring properly.
Animus is offline
post #4 of 8 (permalink) Old 02-19-2017, 05:35 PM
Reviews: 120
Talk to Hantug Custom Guitars, they have an EZ II option. It looks to be the one with zero point, but I'd bet they'd be able to help you out with some info provided by you.
https://www.hantug.com/index.php?rou...product_id=137
LonePhantom is offline
post #5 of 8 (permalink) Old 12-30-2018, 08:52 AM
Wondering if you ever found an answer to this question and bought a sustain block?
The used JEM BFP2 I just purchased has the same setup as your photos. An Edge zero point II Trem but no zero point system with it, just three spring screws for the claw. Would be interested in trying to replace it with a brass sustain block.
The TPS Report is offline
post #6 of 8 (permalink) Old 12-30-2018, 10:24 AM
So email the manufacturers, they can easily modify the block to take a third spring instead of the ZPS system.
sepulchrave is offline
post #7 of 8 (permalink) Old 12-30-2018, 12:51 PM
Drill a hole right in middle yourself. I recommend a drill press. If you don't have one surely you've got a friend with a grandpa that has one. Grandpa's are good at having good tools.
snaggleyoda is offline
post #8 of 8 (permalink) Old 01-11-2019, 06:27 AM
wouldn't the Ibanez® Edge from hantug fit? worse case find a used edge zero ii plate and modify it to match the new block.
xinap is offline
ibanez trem sustain block
Brass block for Edge Zero ii 7burn Tech: Setup, Repairs and Mods 0 02-12-2016 08:58 PM
Gibson Axxis Floyd Rose black w/ 42mm brass sustain block Getcha pull Classified Ads: Guitars and Gear 0 06-21-2012 01:12 PM
Question about upgrade brass sustain block for Original Edge leathermonkey7 Gear, Equipment, Recording & Off Topic 2 04-01-2012 11:13 PM
WTB Edge Pro 7 Trem Block (sustain block) magic_golem Classified Ads: Guitars and Gear 0 04-24-2011 02:49 PM
FT: Floyd Rose Brass Trem Block for Ibanez Edge Block t1r12003 Classified Ads: Guitars and Gear 0 02-27-2009 08:19 PM
