Edge III arm trouble - Jemsite
post #1 of 5 (permalink) Old 01-26-2010, 10:15 PM Thread Starter
Hi all,
Just bought an RGT42DX, nice guitar with crap stock pickups which will upgrade as soon as more $$ comes in!
Having a problem with the EdgeIII trem arm - I got the gtr without an arm, and picked up a replacement from Guitar Center (part #2LE2-1B), Unfortunately this replacement arm doesn't fit into the socket. It stops when the 1st washer is halfway down the socket. No visible damage to the socket, but putting a dowel into the socket shows there's a good 1/2 inch further (or more) that the arm could have gone in.
Ibanezrules.com states that the correct replacement arm for the Edge III is a 2EL2C1B (but they're backordered now). Can anyone shed further light on the subject? Do I in fact need to use a different part #? Or are the 2LE2-1B's a universally usable arm?
Thanks,
ArtC
gamesounds is offline
post #2 of 5 (permalink) Old 01-27-2010, 02:57 PM
Re: Edge III arm trouble
The one you bought from GC with the little white washers only works on higher end Edge tremolos, Edge Pro, Edge LoPro. They tried to sell the same thing to me at GC but luckily I knew more than them. The arm for Edge Pro II/Edge III is just a black bar, no washers. It's a little skinnier than the normal Edge bar.
CrossingStar is offline
post #3 of 5 (permalink) Old 01-27-2010, 03:28 PM Thread Starter
Thanks for the info!
Now I have to figure out where to get one from... I would think they should be easy enough to find, but that doesn't seem to be the case
post #4 of 5 (permalink) Old 01-27-2010, 08:03 PM
Originally Posted by gamesounds View Post
Thanks for the info! Now I have to figure out where to get one from... I would think they should be easy enough to find, but that doesn't seem to be the case
I ended up special ordering from GC. Took 3-1/2 months! I believe Ibanez has a web store now and you could also try Ibanezrules.com.
post #5 of 5 (permalink) Old 01-28-2010, 04:10 AM Thread Starter
Found one off ****.. the seller is 30 miles from my place
Thanks for your help!!
edge iii , setup , tech , tremolo arm
RG770dx - Edge Trouble Dethroned Tech: Setup, Repairs and Mods 5 01-16-2010 08:55 PM
Edge Pro arm holder trouble ChopDuel Tech: Setup, Repairs and Mods 3 03-25-2007 06:18 AM
Lo-pro edge trouble CodFather All Other Guitars (including Prestige) 6 05-15-2004 08:51 AM
TRS trouble Toolhead All Other Guitars (including Prestige) 3 03-08-2003 06:11 PM
Trouble w/ Arm Holder Spring in Lo-Pro Edge - Help! elfstones Tech: Setup, Repairs and Mods 11 03-31-2002 02:25 PM
