Edge III replace with Edge Zero? - Jemsite
post #1 of 6 (permalink) Old 01-17-2013, 03:39 PM Thread Starter
Smile Edge III replace with Edge Zero?
Hi, I was wondering if it's possible to replace the edge iii with an edge zero bridge without the zero point system in the back using 2 of the springs attached to the block, if not what modifications would I need to make to the body? thanks
Ericson is offline
post #2 of 6 (permalink) Old 01-17-2013, 04:13 PM
Re: Edge III replace with Edge Zero?
I believe the edge zero is a much bigger route. So I do not think it would fit without some routing.
dickicker is offline
post #3 of 6 (permalink) Old 01-17-2013, 04:21 PM
Reviews: 120
Too much work. Replace with an Edge Pro, just replace studs and anchors and you're done.
LonePhantom is offline
post #4 of 6 (permalink) Old 01-17-2013, 04:26 PM
RGTFanatic's Avatar
This is EXACTLY what I would do!!!
The Edge Pro is an excellent trem....especially with locking studs!!!!
RGTFanatic is offline
post #5 of 6 (permalink) Old 01-17-2013, 05:08 PM Thread Starter
reason i ask is because Im thinking of getting an egen8 and changing the hardware/bridge
Ericson is offline
post #6 of 6 (permalink) Old 01-17-2013, 06:17 PM
RGTFanatic's Avatar
The Edge Zero won't drop in directly. You'll have to do some serious modding to both the trem route and the spring cavity route to make it work.
edge zero
Replace Edge Zero ZPS3 to Lo pro Edge raflemos All Other Guitars (including Prestige) 12 06-14-2012 10:39 PM
Can I replace Jackson JT580 with Edge Pro or Edge III Tremolo? Izzyprad Tech: Setup, Repairs and Mods 11 05-04-2010 08:57 AM
Replace Edge-ZERO with Original-EDGE? SilverEra Tech: Setup, Repairs and Mods 7 06-25-2009 03:36 AM
Can you replace an edge trem with a LoPro Edge? - Is it poss Cycovision Tech: Setup, Repairs and Mods 7 05-16-2009 12:22 AM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 12:18 PM
