edge or lo-pro edge on ibanez rg350 - Jemsite
post #1 of 5 (permalink) Old 12-02-2009, 02:40 PM Thread Starter
Hi friends
Can i put edge or lo-pro edge on ibanez rg350????
what is routing???
please help me can i put original edge or lo-pro edge in edge 3 cavity????
saeed-satriani is offline
post #2 of 5 (permalink) Old 12-02-2009, 02:51 PM
Re: edge or lo-pro edge on ibanez rg350
From the top of this very page:
http://www.jemsite.com/forums/f21/ed...olo-68062.html
djohns74 is offline
post #3 of 5 (permalink) Old 12-02-2009, 05:40 PM
Reviews: 3
Please try to use the Search function next time.
No, simply you can't.
Your best deal is to get an Edge Pro or an OFR.
OFR will need some sanding at the back of the cavity.
Edge Pro will be a direct drop, but you won't be able to use the studs came with the Edge Pro unless you route deeper in the Stud hole, however, you can use the Edge 3 studs.
That's all.
Yamadron is offline
post #4 of 5 (permalink) Old 12-03-2009, 03:28 AM Thread Starter
That's all.
thanck you
So i can not put edge or lo-pro on my ibanez but what is that bridge he have rg350dx but he put lo-pro on his guitar!!!!!!!!!http://64.15.120.236/watch?v=W1cAg04...eature=related
i dont know can i put edge or lo-pro on my ibanez or not???????
post #5 of 5 (permalink) Old 12-04-2009, 10:42 AM
While you CAN put an Edge on your 350. The real questions are; SHOULD you and do you have the skill? As for "SHOULD you?" I think you would be happier by selling/trading the 350 for an RG5xx or a newer Prestige RG with the Edge Pro which will result in you owning a much better guitar. As for "do you have the skill?", I suspect not(because you asked what is routing) (no offense is intended here). The success of this mod depends greatly on both your routing skills AND your setup skills. For this mod to work well, the old studs and inserts should be removed and new Edge locking studs and inserts should be installed. Then the wood should be routed to fit the new bridge, both for space around the rim, AND depth so the new bridge has room for movement.
albee1952 is offline
edge , lo-pro
original edge or lo-pro edge on ibanez rg350 saeed-satriani Tech: Setup, Repairs and Mods 4 12-11-2009 02:56 PM
FT Ibanez Edge Pro Powder Cosmo Black for Edge Pro Gold supergirl20_06 Classified Ads: Guitars and Gear 2 12-02-2009 11:05 AM
FT Ibanez Edge Powder Cosmo Black for Edge Pro Gold supergirl20_06 Classified Ads: Guitars and Gear 1 06-26-2009 05:45 PM
WTB: Ibanez edge/LP edge/edge pro saddle mounting screws Ratit Classified Ads: Guitars and Gear 0 04-18-2009 09:16 PM
OFR vs. Ibanez Trems (Edge, Lo-pro, Edge Pro) guitarman13 Tech: Setup, Repairs and Mods 12 01-07-2007 12:58 PM
