Edge / Lo Pro Edge are squeaky - Jemsite
post #1 of 6 (permalink) Old 01-06-2016, 02:27 PM Thread Starter
I have a couple RGs that are making a squeaking sound when I turn the bar in the bridge's socket. Edge and Lo Pro. How do I make this go away? Some simple oil somewhere?
Thanks!
Steveche is offline
post #2 of 6 (permalink) Old 01-06-2016, 02:33 PM
Re: Edge / Lo Pro Edge are squeaky
A little dab of grease in the detent on the bar, it's the spring squeaking as it turns. Try not to get it anywhere inside the holder if you want the bar to stay in place.
Rich is offline
post #3 of 6 (permalink) Old 01-06-2016, 03:08 PM Thread Starter
Ah, just in the groove right under the bushings?
Steveche is offline
post #4 of 6 (permalink) Old 01-06-2016, 03:29 PM
Yes..
Rich is offline
post #5 of 6 (permalink) Old 01-06-2016, 05:52 PM Thread Starter
Yes..
Thanks Rich. Out of curiosity, should a specific amount of the spring be sticking into the socket? When I got the 3120, the spring was out so the trem arm wasn't popping in, so when I took the bridge off I really stuck the spring in as much as I could (and tightened in place) so the arm could pop in firmly. Is it possible to have it in "too much"?
Steveche is offline
post #6 of 6 (permalink) Old 01-06-2016, 06:10 PM
For the last 5 years they've had a bug where the hole got smaller and the spring jammed on the edge and wouldn't catch the detent much if any, now cured. All you did by deep setting it is increase it's pressure a little. It may or may not be causing the squeak.
Rich is offline
WTT: Edge/Lo-Pro Edge Whammy bar for Edge III (black) GuitarAl96 Classified Ads: Guitars and Gear 0 07-25-2013 10:30 AM
How can I check whether my RG2570 body takes an Edge Pro or Edge Zero trem? JayCartay All Other Guitars (including Prestige) 6 11-18-2012 06:23 PM
LF: Lo-Pro Edge, Edge Pro or Edge Pro II in Madrid Spain kevlahnota Classified Ads: Guitars and Gear 2 03-24-2010 11:40 AM
WTB: Ibanez edge/LP edge/edge pro saddle mounting screws Ratit Classified Ads: Guitars and Gear 0 04-18-2009 08:16 PM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 12:18 PM
