Edge Pro - Jemsite
post #1 of 14 (permalink) Old 11-25-2011, 08:34 AM Thread Starter
Edge Pro
just had my Jem77V BK set up and noticed the edge pro is not level. right hand side is flush with body and left is a good 5mm or more above body. questioned the guitar guy and he said thats how they are. thought the were to be equal level on both sides. the guy i went to has a great reputation. am i wrong.
metalupya is offline
post #2 of 14 (permalink) Old 11-25-2011, 08:41 AM
Re: Edge Pro
to an extent. Your treble side of your bridge with be lower than your bass side if you've adjusted the string height correctly. It all comes down to personal preference though in regards to string height.
TMatt142 is offline
post #3 of 14 (permalink) Old 11-25-2011, 09:02 AM
Re: Edge Pro
5mm seems excessive to me. Yes the bass side is generally higher because the wound strings oscillate more and need more clearance between the fret and the string. Mine are generally about 1/64th difference in action. 5mm really seems up there.
gideond is offline
post #4 of 14 (permalink) Old 11-25-2011, 11:10 AM
Re: Edge Pro
Correct...I read back through and saw the OP had measured it....That's the beauty about guitars. Each one is different from the other. Some of my trems are flat, some I've had to jack up the low E (or B) side....
TMatt142 is offline
post #5 of 14 (permalink) Old 11-25-2011, 03:19 PM
Re: Edge Pro
5mm sounds too much to me! In the end it's a matter of personal preference. If you like the string height as is....fine! If you'd like a little lower setting on the bass side, loosen the strings, keep the vibrato's knife edges off the poles and turn the pole in (maybe 90 = a quarter round). Retune the guitar, if still too high, repeat all steps.
If the high strings are too low, do vice versa.
If you like it as is, keep it as is.
But NEVER let the knife edges touch the poles while turning them in or out, you might damage the poles/knife edges!!!! I busted my first Floyd Rose because of this, because I didn't know better 15 years ago!
There's no rule that says it MUST be level (even though I personally prefer it that way or maybe with 1mm difference)
Jemanized is offline
post #6 of 14 (permalink) Old 11-25-2011, 04:59 PM Thread Starter
Re: Edge Pro
the guitar is fine to play the way it is set up so i should not be complaining but there is a line on each side of the edge pro and i thought that had to be flush with the body for it to be set correctly.
post #7 of 14 (permalink) Old 11-25-2011, 05:32 PM
Reviews: 11
Re: Edge Pro
if it plays good and stays in tune, its set up correctly. visuals have nothing to do with a correct setup
D.M.RG7620 is offline
post #8 of 14 (permalink) Old 11-25-2011, 07:07 PM
Re: Edge Pro
This is fine to do on an Edge Pro. The knife edges, I believe, are hardened steel. I've had my prestige for 3 years now, and there isn't a hint of wear or damage to the posts or edges.
My Edge III is another story though. The damage isn't too bad, it still functions fine. It is definitely visible though. These are also made out of much cheaper (softer) metals.
xXLinkageXx is offline
post #9 of 14 (permalink) Old 11-26-2011, 08:31 AM
Reviews: 13
Re: Edge Pro
The same thing happened to my edge III, I "thinned" the knife edges following rich's website. The thing works fine now.
DownHomeRock is offline
post #10 of 14 (permalink) Old 11-26-2011, 10:42 AM
Re: Edge Pro
Anyone know why some companies will have one flat and one curved edge on their trems? From what I've read, curved edges wear slower, and from what I've seen on my Edge 3, it's true here. I have some wear on the flat edge, but the curved one looks brand new. I've seen a few trems out there that do use 2 curved edges, don't understand why it's not a standard.
Mark_McQ is offline
post #11 of 14 (permalink) Old 11-26-2011, 11:39 AM
Re: Edge Pro
All of mine have one curved and one flat. The curved one fits right on the post with no room to move left or right. The flat one can be shifted a bit. If your posts aren't absolutely perfectly centered then a doubled curved trem would not seat correctly against the post and cause all sorts of problems. Curved slots don't wear as quickly because the already conform to the shape of the post and make more surface contact. This distributes the pressure across a larger metal area. A flat edge has all the pressure resting on the one tiny point where the edge meets the post.
gideond is offline
post #12 of 14 (permalink) Old 11-26-2011, 02:28 PM
Re: Edge Pro
I had a feeling it would be along those lines. I can definitely see the need for it on an aftermarket trem that would be used on a lot of different bodies, but seems weird to have it on an OEM one that's only fitted on one brand of guitars.
Mark_McQ is offline
post #13 of 14 (permalink) Old 11-27-2011, 12:30 PM
Re: Edge Pro
I'd say you are more likely to see a double curved one on a higher end guitar where they are being very precise during construction and setup. On lower to mid range production models accuracy from one guitar to the next will still vary a bit. Besides that, if you are using the same trem on a $500 production guitar as you are on a $2000 custom shop guitar it still doesn't make sense to go through the expense of making two different models of the same trem.
gideond is offline
post #14 of 14 (permalink) Old 11-27-2011, 02:13 PM
Re: Edge Pro
Rich has probably at least a hundred posts on this forum debating with people whether this is necessary. He says any high end edge, the OE, LP, EP, or EZ1/2, will be absolutely fine with changing the action under tension.
The lower end models like Edge 3, he recommends not changing action with strings on.
GuitarBizarre is offline
WTB: square heel neck and edge/lopro edge needed nafigator Classified Ads: Guitars and Gear 0 03-27-2011 05:41 PM
LF: Lo-Pro Edge, Edge Pro or Edge Pro II in Madrid Spain kevlahnota Classified Ads: Guitars and Gear 2 03-24-2010 11:40 AM
FT Ibanez Edge Pro Powder Cosmo Black for Edge Pro Gold supergirl20_06 Classified Ads: Guitars and Gear 2 12-02-2009 10:05 AM
WTB: Ibanez edge/LP edge/edge pro saddle mounting screws Ratit Classified Ads: Guitars and Gear 0 04-18-2009 08:16 PM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 12:18 PM
