edge pro block not perpendicular to plate - Page 2 - Jemsite
post #16 of 19 (permalink) Old 01-29-2016, 08:05 AM Thread Starter
Re: edge pro block not perpendicular to plate
It worked!!! 16mm and it works perefectly, thanks @steve
Originally Posted by steve View Post
I bought replacement stainless steel screws - the stock shorter screws are indeed prone to coming loose, especially with high string/spring tension scenarios...
*touch wood* the longer (15mm) screws I put in made for a much better strong hold... the stock ones came loose within a day....
I believe they are M3, and you need countersunk head, and I recommend getting hex head ones while you're at it... less prone to burring up with a good hex wrench.
(And I recall that 15 or 16mm was the maximum depth that would work in there regarding the threaded holes' depths etc.)
hmoller is offline
post #17 of 19 (permalink) Old 01-29-2016, 06:38 PM
Ah excellent - good stuff.
Certainly solved my issue with my one particular EdgePro7 from a 2003 RG1527CB that I acquired in remarkable condition, but I found was plagued with this same issue - the block was loose, and kept working loose repeatedly, and fairly quickly.
15/16mm screws as above, and *knock on wood* that baby's been solid ever since.
steve is offline
post #18 of 19 (permalink) Old 04-03-2017, 10:25 PM
Where did you guys get your mythical 16mm's? I tried finding some all day with no luck haha
Opendome is offline
post #19 of 19 (permalink) Old 04-03-2018, 06:36 AM
@Opendome : You can search for them on the internet, just use M3 and 15mm (or 16mm) as keywords. They're fairly cheap as well you can get 10 screws for about $1.
soapbar is offline
angled , edge pro , edge pro block , screw
Edge Pro blaock replacement with Edge III block,is this possible? ritchwie All Other Guitars (including Prestige) 5 08-25-2015 10:04 AM
WTB Edge Pro 7 Trem Block (sustain block) magic_golem Classified Ads: Guitars and Gear 0 04-24-2011 02:49 PM
FT: Floyd Rose Brass Trem Block for Ibanez Edge Block t1r12003 Classified Ads: Guitars and Gear 0 02-27-2009 08:19 PM
For Trade: 31mm Edge spring block for 41mm block mtxsho93 Classified Ads: Guitars and Gear 0 04-02-2007 05:29 PM
FS:Ibanez Pickups/Edge/RG7 Plate set/Neck plate Jem7RB MK Classified Ads: Guitars and Gear 10 02-22-2005 04:52 PM
