Edge Pro bridge problem: About that ring inside the tremolo hole - Jemsite
post #1 of 6 (permalink) Old 04-06-2013, 06:22 AM Thread Starter
Hi guys. I am not sure if this is already discussed somewhere here. I tried the Search function but didn't get any which can be helpful so I decided to make a thread about it.
After semi-excessive whammy antics on my Edge Pro, I always notice that the ring inside the tremolo hole is raised up. See my diagram here :
The ring is not supposed to be raised so my temporary solution was to rotate the screw found at the back as seen here :
Note also that that thing in the arrow of the 2nd picture is wiggle and somewhat loose when while I am in this situation.
While I use a pick to rotate the ring downwards, I rotate the screw at the back in an opposite direction. I continue to do so until I've reached a spot where the ring is not raised and at the same time, both the ring and the screw at the back are tight.
However, once I get to abusive whammy antics again, the same thing happens.
Is there something wrong with my bridge? Or am I doing something wrong? PLease help me to find a permanent solution for it.
Thanks
rye715 is offline
post #2 of 6 (permalink) Old 04-06-2013, 11:41 PM
Re: Edge Pro bridge problem: About that ring inside the tremolo hole
http://www.ibanezrules.com/tech/setup/loose_holder.htm
Rich is offline
post #3 of 6 (permalink) Old 04-07-2013, 09:22 AM
Exactly.
Takin' a Ride is offline
post #4 of 6 (permalink) Old 04-07-2013, 04:17 PM
I made my own tool for tightening the pocket. I looked through some spare metal hinges and brackets sitting I had and found this one to be almost a perfect fit, just a little wide, so i shaved a bit off one side and now it fits perfectly in the slot with no room to slip.
kfm946 is offline
post #5 of 6 (permalink) Old 04-07-2013, 04:20 PM
CosmicDebris's Avatar
I made my own out of the teeth of a baby fur seal. If you make your own tooth tool make sure you club the seal first otherwise they fight like hell.
CosmicDebris is offline
post #6 of 6 (permalink) Old 04-08-2013, 01:30 AM Thread Starter
Thanks for all the answers guys.
As of now, I really am afraid to remove the bridge and put it back again. There's no guitar luthier within a 10 mile radius from my place so I guess I have no choice but to do the same old method that I do for the time being.
On the brighter side, at least I know now how will it be fixed. Thank you again
rye715 is offline
tremolo ring
Problem with Edge Tremolo PinkSpId3r Tech: Setup, Repairs and Mods 9 08-25-2008 11:40 PM
Problem with Tremolo Bar Staying In Bridge Drow Swordsman All Other Guitars (including Prestige) 4 05-13-2006 09:31 AM
Edge Tremolo problem phil27 Tech: Setup, Repairs and Mods 3 02-02-2005 06:22 AM
Problem with my Lo Pro Edge Tremolo!!! Wont keep pitch!! quiel Tech: Setup, Repairs and Mods 25 06-15-2004 12:25 PM
supposed problem with EDGE tremolo machinediva Tech: Setup, Repairs and Mods 1 08-28-2003 01:22 PM
