Edge Pro - D string saddle - Jemsite
post #1 of 5 (permalink) Old 10-02-2011, 08:23 PM Thread Starter
Question Edge Pro - D string saddle
I've been tweaking my RG1570 after my last string change and I noticed something that I would like to get confirmed.
From what I understand, the Edge Pro radius is factory set to 430mm. When looking at my Edge Pro, the D string saddle looks like its too low for some reason. When I look at the trem from behind, this is what I see:
  • the high E and low e are set the lowest
  • the D and B are the next lowest
  • the A and G are set the highest
Does anyone else have the same issue? Also, what can I do to change saddle height?
Thanks in advance!
dj
djem is offline
post #2 of 5 (permalink) Old 10-02-2011, 09:06 PM
Re: Edge Pro - D string saddle
Check to make sure one of the lockdown screw washers isn't under a saddle.
Rich is offline
post #3 of 5 (permalink) Old 10-03-2011, 09:00 PM Thread Starter
No washers wedged in there.
What concerns me is that I think that the D and G saddles should be set the highest as they are at the top of the radius, but my D saddle is ~ 1mm or so lower than the G. When you look at the strings from the low E side, the D string appears lower.
Am I messed up with this logic?
djem is offline
post #4 of 5 (permalink) Old 10-03-2011, 10:42 PM
Most serious radius problems were typically on the eariest, 2003ish trems. All you can do is shim to radius.
Rich is offline
post #5 of 5 (permalink) Old 10-18-2011, 11:33 AM
Shim it.
shotgunn is offline
edge pro
Edge III string saddle arrangment asolid Tech: Setup, Repairs and Mods 4 06-23-2012 11:04 PM
WTB: Ibanez edge/LP edge/edge pro saddle mounting screws Ratit Classified Ads: Guitars and Gear 0 04-18-2009 08:16 PM
LO TRS STRING SADDLE!!!!!!!! #2 zzzec Tech: Setup, Repairs and Mods 1 12-06-2007 06:54 PM
Edge saddle _FR0D0 Tech: Setup, Repairs and Mods 16 04-23-2003 04:44 PM
A saddle in the lo-pro edge rattles...? - Help, B string sad darthpolster Tech: Setup, Repairs and Mods 9 12-17-2002 05:09 AM
