edge pro and lo-pro edge - Jemsite
post #1 of 18 (permalink) Old 01-15-2006, 02:11 AM Thread Starter
How can you tell the difference, if my guitar is a prestige rg from 2004, would it have a lo-pro, or an edge? If it has a lo-pro, and sits at the angle the edge pro is supposed to sit at, does that make a big difference?
Pikaciao is offline
post #2 of 18 (permalink) Old 01-15-2006, 02:51 AM
Re: edge pro and lo-pro edge
The Edge-Pro was introduced in 2003. Pre 2003 models came with Lo-Pros.
King Knall is offline
post #3 of 18 (permalink) Old 01-15-2006, 03:04 AM Thread Starter
I have an edge pro then. I have a big problem, I started a topic before about this, rich gave me a link, but it didn't really tell me anything new, I change strings and tune the way it is supposed to be done. The problem is that the bridge doesn't return to 0, I know it is impossible for a bridge to return 100%, but mine, if I pull it back(to raise in pitch) it returns leaving the strings +8/+9 out of tune, if I push down on the bar(lowering pitch) it returns leaving strings -2/-3 out of tune, this is surely not supposed to happen? It has recently been professionally set up, including fret dress and everything else. The trem is at the correct height it is supposed to be at. Is this because the edge-pro sucks? What is the logic behind making a worse trem than before on newer models? Why fix what isn't broken?
Pikaciao is offline
post #4 of 18 (permalink) Old 01-15-2006, 03:10 AM
1570L, and the link I sent was lockdown procedure which you are not following. The trem when set and tuned in low neutral should always return to low neutral [bar down]. Pull up is another bag altogether.
Rich is offline
post #5 of 18 (permalink) Old 01-15-2006, 03:18 AM Thread Starter
It returns acceptable after pushing down on the bar, the other way, pulling up, leaves it miles out, as I've said, so, if I follow this procedure, this will stop happening? I don't get what you mean by another bag altogther. Do you mean it can't be fixed?
Pikaciao is offline
post #6 of 18 (permalink) Old 01-15-2006, 03:21 AM
If you follow correct procedure this should not happen unless you have another problem. And, no, procedure isn't going to sure the pullup problem, read my email rply again.
Rich is offline
post #7 of 18 (permalink) Old 01-15-2006, 03:26 AM Thread Starter
Hello. I did not send you an email regarding this problem, maybe it was someone else, but it's the pull up problem I would like to solve, if possible.
Pikaciao is offline
post #8 of 18 (permalink) Old 01-15-2006, 03:39 AM
I guess you're not the guy with the 1570L then
Rich is offline
post #9 of 18 (permalink) Old 01-15-2006, 03:41 AM Thread Starter
Close, 2570E? I think. Could you give me a fix for this issue? I should have said I didn't have the 1570l, but I didn't understand what you meant.
Pikaciao is offline
post #10 of 18 (permalink) Old 01-15-2006, 03:44 AM
No, I have about 8000 in this sent box.
Check for pickguard interference.
Otherwise
Another link
http://www.ibanezrules.com/tech/setu..._stability.htm
Rich is offline
post #11 of 18 (permalink) Old 01-15-2006, 03:49 AM Thread Starter
It doesn't have a pickguard. As for issues, this guitar is not old, and hasn't recieved serious whammy abuse. The knife edges or posts could not be worn to an extent that they would create problems.
Pikaciao is offline
post #12 of 18 (permalink) Old 01-15-2006, 03:54 AM
No, but there are many related problems on that page, and your curved side knives are extremely fat.
Rich is offline
post #13 of 18 (permalink) Old 01-15-2006, 04:31 AM Thread Starter
What's the device you can install to help with this? It's called zero something.
Pikaciao is offline
post #14 of 18 (permalink) Old 01-15-2006, 07:50 AM Thread Starter
I will just block it, it's more trouble then it's worth, no one should have to go to this amount of trouble to tune a fkin guitar. Amazing the technological advancements we have made since the 80s, and yet these things are still crap.
Pikaciao is offline
post #15 of 18 (permalink) Old 01-15-2006, 07:55 AM
there are things that have been made that improve it eg backstop, esp arming adjuster, hipshot tremsetter
just they dont come as standard on ibanez guitars (or many others!!)
timi_h is offline
edge pros , esp arming adjuster , hipshot tremsetter , ibanez guitars , locking trems
WTT: Edge/Lo-Pro Edge Whammy bar for Edge III (black) GuitarAl96 Classified Ads: Guitars and Gear 0 07-25-2013 10:30 AM
WTB: square heel neck and edge/lopro edge needed nafigator Classified Ads: Guitars and Gear 0 03-27-2011 05:41 PM
LF: Lo-Pro Edge, Edge Pro or Edge Pro II in Madrid Spain kevlahnota Classified Ads: Guitars and Gear 2 03-24-2010 11:40 AM
WTB: Ibanez edge/LP edge/edge pro saddle mounting screws Ratit Classified Ads: Guitars and Gear 0 04-18-2009 08:16 PM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 12:18 PM
