EDGE PRO PROBLEM! PLEASE HELP! - Jemsite
post #1 of 8 (permalink) Old 04-23-2004, 11:09 AM Thread Starter
Hey...please be patient with me because I a n00b in the Edge Pro department.
Whenever I unlock the nut and tune up then lock the nut...I am almostly instantly out of tune...what am I doing wrong??
Also...someone told me to stretch the strings when I replace them...however I misinterpreted it as doing it every time I tune up, when I did it last it raised the bridge above the "neutral" point...how can I lower it?
sorry for my lack of understanding, I would appreciate any help!
thanks!
Adagio_777 is offline
post #2 of 8 (permalink) Old 04-23-2004, 12:09 PM
are the strings going sharp when you tighten the nut? if so you need to lower the string tree thing (the bar on the headstock).
if the bridge has raised above neutral you need to tighten the spring screws in the back of the guitar
matt_cater is offline
post #3 of 8 (permalink) Old 04-23-2004, 12:54 PM Thread Starter
its going flat...
also i thought I wouldnt have to adjust the spring screws in the back of the guitar because I havn't even touched them in the first place...does the TREMOLO somtimes do it for no reason...or mayby because I was stretching the strings which resulted in it raising above the neutral line?
thanks!!!
post #4 of 8 (permalink) Old 04-23-2004, 03:41 PM
Originally Posted by ESPEXPLORER351D
its going flat...
See if the nut is sitting thight.
Jeroenn is offline
post #5 of 8 (permalink) Old 04-23-2004, 03:48 PM Thread Starter
Hey...I noticed that, the nut not being tight enough is the problem...Im such a sissy im scared to be a bit rough with it
thanks!
post #6 of 8 (permalink) Old 04-23-2004, 04:56 PM
It's not made of cheese..
cheers,
Jeroenn is offline
post #7 of 8 (permalink) Old 04-24-2004, 03:09 AM
its going flat...
Exactly this was the problem with my RG570 a while ago. I was going nuts with it and just couldnīt find the problem. Then finally I noticed that the nut moved a bit when I tigthtened the locking pads. I tightened the nut and the problem was solved. Man I was relieved!!
Heka is offline
post #8 of 8 (permalink) Old 04-24-2004, 05:25 AM Thread Starter
hehe yeah...
you need to make sure its deadly straight also dont you?
string tree
Edge Pro Problem pwsusi Tech: Setup, Repairs and Mods 2 12-27-2013 05:28 PM
Edge III bar problem MikeAHBL Tech: Setup, Repairs and Mods 2 06-09-2010 03:12 PM
edge 3 problem prydogga Tech: Setup, Repairs and Mods 3 01-07-2009 08:31 PM
Lo pro edge & Double Edge in tune problem Raffel Tech: Setup, Repairs and Mods 21 05-14-2004 08:59 AM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 01:43 PM
