Edge pro touching to the pickguard - Jemsite
post #1 of 3 (permalink) Old 11-12-2004, 10:17 AM Thread Starter
The corner of the edge pro touches the pickguard a little (not the tremolo arm side)
how can I solve it
the guitar is a new jem
I adjusted the bridge height only ( I lowered it a little bit)
then when I see it touching the pickguard I raised the upper side and lowered the lower side and vice versa but there is still a slight touch
the bridge angle seems ok (tightened the back screws about a quarter turn)
and exactly where I must look for checking the angle the sides of the bridge are nut parallel to the saddles
and is it ok if the bridge is bent forward a little
the action is medium about 2mm on low E and 1.7 mm on high E and there is no buzz
Stormcrow is offline
post #2 of 3 (permalink) Old 11-12-2004, 10:45 AM
Rich is online
post #3 of 3 (permalink) Old 11-12-2004, 10:59 AM Thread Starter
thanks when I first got the guitar it was not like this after I changed the biridge height it gets a contact in the corner
bridge angle , tremolo arm
Pickguard edge polishing moonlight Tech: Setup, Repairs and Mods 3 08-06-2011 05:50 PM
edge 3 - lower strings touching fretboard thehungryhippo Tech: Setup, Repairs and Mods 6 01-12-2011 03:39 PM
Strings buzzing when not touching them... SomeDude49 All Other Guitars (including Prestige) 3 09-05-2007 06:17 AM
Touching up edge. gemm012 Tech: Setup, Repairs and Mods 11 07-11-2006 01:31 AM
Touching Up the Paint? lonewolf121188 Tech: Setup, Repairs and Mods 0 06-18-2006 06:32 PM
