Edge pro tuning problem - Jemsite
post #1 of 4 (permalink) Old 12-17-2018, 11:41 AM Thread Starter
Hi,
I've been having some pretty bad tuning stability problems with my Edge Pro equipped RG1570. I've had the guitar for around 10 years, but barely used the tremolo and only got these problems recently. Basically If I tune normally and lock down the string at the nut and start tuning at the fine tuners all of the strings go out of tune while doing the fine tuning, some of the strings go down in pitch almost 15 cents. It's impossible to get all of the strings in correct pitch. Also if I push down with the tremolo arm, the string will go flat even more. If I then raise the bar, the strings will return to rougle the same pitch they were previously.
I have already read Rich's guide to trem setup and checked that the following isssues are not the cause.
-neck joint is tight
-strings are not slipping in the nut
-locking nut is tight and not moving
-springs have been changed and strings are new and streched
- knife edges are not perfect, but not so bad that they would be the cause in my opinnion
-Intonation screws are tight and saddles are tight in place on the bridge
-The trem stud inserts are thight in the bod and not moving
-the tension plate thats pusing the fine tuning from below is giving each tuner adequate pressure
Some observations:
-I can see very minor wear on the posts( could the posts actually wear out faster than the knife edges and cause such bad tuning issues?)
-if the trem is taken off, the studs sit very loosely in the inserts, but I think they are supposed to be like that(?)
I hope someone can give some thoughts on whats causing this problem?
llamaolakase is offline
post #2 of 4 (permalink) Old 12-17-2018, 11:51 AM
Re: Edge pro tuning problem
You can replace the pivot posts with brand new locking posts from the original Edge/Lopro to get rid of that unhelpful looseness, this will eliminate wear and movement as possible causes leaving only knife-edge condition as a possible cause.
sepulchrave is offline
post #3 of 4 (permalink) Old 12-19-2018, 09:12 AM Thread Starter
Do you think the wear of these parts can cause the problems I'm having? it's not just tuning stability problem when using the them, I mean I'm completely unable to tune the guitar to perfect pitch. Tuning with the fine tuners will result in other string's tuning going off.
post #4 of 4 (permalink) Old 12-19-2018, 10:38 AM
Look, this is a simple mechanical issue, there's no black magic at work here, no supernatural forces or malignant spiritual entity.
The tremolo bridge will not stay in balance so every time you change the tension of one string the entire bridge moves enough to change the tuning, if the bridge is sticking then it's either the knife edges or the posts or both.
edge pro , issues , problem , tuning
Ibanez Lo-Pro Edge Tuning Problem VexHead All Other Guitars (including Prestige) 15 08-26-2011 03:10 PM
LF: Lo-Pro Edge, Edge Pro or Edge Pro II in Madrid Spain kevlahnota Classified Ads: Guitars and Gear 2 03-24-2010 12:40 PM
Edge Pro Tuning Stability Problem TheYoungGuitarist Tech: Setup, Repairs and Mods 1 01-14-2009 10:10 PM
Edge Pro vs Edge Pro II vs. Edge Pro III ColinMmmmm Tech: Setup, Repairs and Mods 16 12-21-2007 12:26 PM
edge tuning problem - edge tuning problem johank Tech: Setup, Repairs and Mods 1 10-03-2001 10:30 AM
