Edge - spring questions. - Jemsite
post #1 of 7 (permalink) Old 11-24-2005, 05:01 AM Thread Starter
I've just got hold of a '88 DY and have changed the strings from 10's to 9's. How should the tremolo springs be set up?
Do i use 2 or 3? Straight or arrow alligned?
2 of the springs are the same size and 1 is shorter. Is this correct?
Any help would be much appreciated.
guitars'r'us is offline
post #2 of 7 (permalink) Old 11-24-2005, 05:32 AM
Re: Edge - spring questions.
I havnt used 9s in a while cause i use 11s now but when i did i used 3 springs in a straight configuration. I suppose you could also use the two longer springs like this / \ the point being the claw end. I havnt tried that config so im not sure how much tension it gives but ive been told it can hold 9s. The different spring length is strange though. Mine have all equal length springs .
ibanez.shredder is offline
post #3 of 7 (permalink) Old 11-24-2005, 05:39 AM
megadeth's Avatar
i recently replace 9s with 10s in the jpm and the bridge was angled sky high. I am thinking of putting 4 spring in this manner.
I think rich also sets up the guitars with 4 springs for 10s.
megadeth is offline
post #4 of 7 (permalink) Old 11-24-2005, 05:51 AM
You definatly shouldn't need 4 springs for 9s man. Ive used 3 in a straight config with 11s for ages with plenty of adjustment room left.
post #5 of 7 (permalink) Old 11-24-2005, 11:33 AM
ScottB's Avatar
He says he switched from 10s to 9s. The Ibanez factory setup of 3 springs in a straight configuration will do just fine. You should have all 3 springs the same length.
ScottB is offline
post #6 of 7 (permalink) Old 11-24-2005, 11:56 AM Thread Starter
1 spring is definately shorter than the other. I'm going to get three new ones and run then straight.
Thanks for the help.
post #7 of 7 (permalink) Old 11-24-2005, 11:59 AM
kennydoe's Avatar
When you get new springs, they're going to be pulling like like a fat girl in a tug-of-war. You'll need to loosen the claw screw a LOT from where they are now. Get three springs.
There are methods in the jemsite tech section for stretching your springs faster than just doing them naturally.
~K
kennydoe is offline
where to buy spring for an edge tremolo? StrunkInPanic Gear, Equipment, Recording & Off Topic 4 12-18-2012 09:19 PM
I need Edge PRO saddle spring HELP! Ekim Tech: Setup, Repairs and Mods 4 01-07-2012 11:28 PM
Edge Pro with Edge Zero Spring / Adjustment mechanism scotteggshell All Other Guitars (including Prestige) 2 08-25-2009 08:11 PM
Edge Spring Claw Screw? Jemmm Ibanez JEM, UV, JS & Other Signature Models 1 04-03-2009 02:49 AM
Edge Trem Spring sam_m Tech: Setup, Repairs and Mods 3 03-03-2005 10:34 AM
