Edge trem arm holder nut- tighten?? - Jemsite
 1Likes
post #1 of 16 (permalink) Old 07-16-2019, 08:17 AM Thread Starter
Hi, any help with this welcome.
On my recently acquired Jem 7V the tremolo arm holder tends to spin loose, particularly when the trem arm is rotated anticlockwise. I assume the arm holder nut is loose but its super awkward to access.
From the rear cavity, my recessed socket wrench is too short to reach the nut due to the length of the arm holder. From the front (with the tremolo fully pushed up in dive bomb position) the space is still too tight to put a spanner on the nut without gouging the finish around the tremolo cavity.
There's surely an easier way to tighten this nut without taking the bridge apart and wrecking the setup?!
Tinman is offline
post #2 of 16 (permalink) Old 07-16-2019, 09:20 AM
Re: Edge trem arm holder nut- tighten??
IBANEZ RULES!! tech - setup
peromucho7 likes this.
Rich is offline
post #3 of 16 (permalink) Old 07-16-2019, 03:03 PM Thread Starter
Originally Posted by Rich View Post
Thanks. A relatively easy fix after reading that.
Unfortunately I decided to up my string gauge while the rear cover was off (from 9-9.5)...not so straight forward! A couple of hours and a 4th spring later and I’ve just about got it setup correctly, I think.
Tinman is offline
post #4 of 16 (permalink) Old 07-18-2019, 12:00 AM
I just joined the forum so there are so many things I don't know yet, I hope to have the help of the boards, and I really want to get to know you all on the forum.
goalken is offline
post #5 of 16 (permalink) Old 07-18-2019, 12:02 AM
It is wonderful to be here with everyone, I have a lot of knowledge from what you share, to say thank you, the information and knowledge here helps me a lot
goalken is offline
post #6 of 16 (permalink) Old 07-18-2019, 09:10 AM
Unfortunately I decided to up my string gauge while the rear cover was off (from 9-9.5)...not so straight forward! A couple of hours and a 4th spring later and Iíve just about got it setup correctly, I think.
You shouldn't need 4 springs with 9.5-44. In fact, up to 10-46 you should be ok with 3 springs
Santir79 is offline
post #7 of 16 (permalink) Old 07-18-2019, 09:58 AM Thread Starter
That’s what I expected but the bridge flew up, even with the claw screws turned to tighten the springs.
Tinman is offline
post #8 of 16 (permalink) Old 07-18-2019, 10:01 AM
How old are those springs then? You might need some new ones. But only if pushing the bar down is hard (normally it is with 4 springs)
Santir79 is offline
post #9 of 16 (permalink) Old 07-18-2019, 10:04 AM Thread Starter
It’s a new guitar! Had it 3 weeks. Yes the bar now harder to push down.
Tinman is offline
post #10 of 16 (permalink) Old 07-18-2019, 11:11 AM
it sounds strange to me. I use 9.5-44 with my Jems in standard tuning. Never had to add a spring.
Santir79 is offline
post #11 of 16 (permalink) Old 07-18-2019, 01:12 PM Thread Starter
I double checked it all and without the 4th spring I “just” run out of enough trem claw screw travel to bring the bridge level. It’s a shame as I probably preferred the trem bar tension with 3 springs. Also, it means the spring locking bar has to be held with only 1 screw as the 4th spring uses a threaded hole in the block. I’ll live with 9.5s for a while and decide if it’s worth it.
Tinman is offline
post #12 of 16 (permalink) Old 07-18-2019, 01:15 PM
You haven't run out of room unless the claw is flush against the wood. If it is your springs are weak.
Rich is offline
post #13 of 16 (permalink) Old 07-18-2019, 01:18 PM Thread Starter
No, hadn’t gone that far in but was meeting quite a lot of resistance so kind of bottled it. The screw was entering wood at the smooth, unthreaded part near the head...that ok then?
Tinman is offline
post #14 of 16 (permalink) Old 07-18-2019, 01:22 PM
You're running into resistance because nobody ever put a heavier gauge on and you're cutting threads. If it's basswood no problem, it it's mahogany I would pull the screws and drill the hole deeper. I have twisted screws in half cutting threads in hard wood.
Rich is offline
post #15 of 16 (permalink) Old 07-18-2019, 01:34 PM Thread Starter
It’s alder (a new 7v-wh). I’ll try again without drilling first. Really appreciate your advice, thanks.
Tinman is offline
tremolo arm nut
