Edge trem two spring setup question - Jemsite
post #1 of 11 (permalink) Old 09-16-2011, 06:19 PM Thread Starter
Hi All,
I am trying to set up my RG550 with original edge trem. I want to use 2 springs but the problem is that when I tune to pitch, the bridge pulls way up (or down I guess)...so I have tried to offset by tightening the screws inside the back cavity, but even when they are screwed all the way in, my Edge is not even close to flush/parallel with the top of the guitar.
Anyone have any ides on how to fix this, or am I destined to use 3 trem springs?
Thanks,
Rob
rbernie28 is offline
post #2 of 11 (permalink) Old 09-16-2011, 06:53 PM
Re: Edge trem two spring setup question
Add a third spring or get stiffer or shorter springs.
I'm not sure what you believe the downside is of using 3 springs? The strings when in tune create a certain amount of tension. The springs need to counteract that tension. It doesn't matter if you use 2, 3 or 10 springs to accomplish that, the total force is the same.
If you want a looser feel, try a drop tuning or lighter gauge strings.
Takin' a Ride is offline
post #3 of 11 (permalink) Old 09-16-2011, 08:43 PM
I play with 9s and two stock springs with a tremsetter in the middle. I just put a new trem in another guitar and it has 10s on it. Too much string tension for two stock springs with a tremsetter. I replaced the stock springs with heavy springs from Floyd Upgrades and they are working out just fine. With no tremsetter you should be able to use up to 5 stock or stiff springs with no issues.
gideond is offline
post #4 of 11 (permalink) Old 09-16-2011, 09:20 PM Thread Starter
My thought is that two springs would result in a looser, spongier feel. I am using 9's. Thanks for the inout,
Rob
post #5 of 11 (permalink) Old 09-17-2011, 01:03 AM
Indeed. Try to get 2 Gotoh springs.
tearsx is offline
post #6 of 11 (permalink) Old 09-17-2011, 08:56 AM
Actually, now that I think about it, less springs should equal looser feel.
Springs basically have a constant rate as they stretch. The total force is that rate times the distance they move. There is an initial fixed amount of force that counteracts the string tension, but then any additional movement of the trem will be just based on the spring rate times the number of springs (assuming you're comparing moving the trem the same distance regardless of number of springs).
Putting that engineering degree to work LOL!
To the OP: your best bet is to get two shorter springs. Click on the Ibanez Rules banner on the top and look in his parts. The standard trem springs are 52mm long and he sells 47mm ones. Try those out.
post #7 of 11 (permalink) Old 09-17-2011, 11:05 AM
RGTFanatic's Avatar
Great explanation Jesse!!!
RGTFanatic is offline
post #8 of 11 (permalink) Old 09-17-2011, 12:30 PM
I have both Gotoh and and Floyd Upgrades stiff springs in hand. They look and feel like the exact same spring to me. I can say that the guitar with the two stiff spring and the new Gotoh tremolo strung with 10s definitely feels much stiffer and harder to dive on that it previously did.
gideond is offline
post #9 of 11 (permalink) Old 09-18-2011, 12:01 PM
Well if you move to stiff springs, you're going to mostly if not completely negate the effect of reducing the number of springs.
post #10 of 11 (permalink) Old 09-19-2011, 11:00 PM
Gotoh springs are blue when new until they fade to yellow.
tearsx is offline
post #11 of 11 (permalink) Old 09-20-2011, 06:57 AM
The ones I have in hand are a greenish color, could be taken for blue I guess. So are the Floyd Upgrades stiff springs. The Gotoh springs came right out of a GE1996T tremolo box.
gideond is offline
Edge setup question mozzo00 Tech: Setup, Repairs and Mods 13 08-03-2011 10:27 AM
Edge Spring Lock question LonePhantom Tech: Setup, Repairs and Mods 15 01-21-2007 01:09 AM
Edge Trem Spring sam_m Tech: Setup, Repairs and Mods 3 03-03-2005 10:34 AM
USRG30 trem spring setup gkelm Tech: Setup, Repairs and Mods 0 11-07-2002 01:36 AM
Dumb question - adding 4th spring on edge block horstausmforst Tech: Setup, Repairs and Mods 17 09-10-2002 08:03 AM
