Edge Zero 2 Problem - Jemsite
post #1 of 2 (permalink) Old 01-17-2016, 07:15 AM Thread Starter
Edge Zero 2 Problem
Hi guys,
I was gifted with a JEM77P, I have worked with a floating tremolo in the past but for some reason what I usually do when I change the strings hasn't worked out on this guitar.
I changed the strings one by one and tuned it up, checked the angle of the tremolo and adjusted it to level with the two springs in the back.
Changed the action a little as the low E seemed higher than usual, then retuned.
The problem is that the guitar now goes out of tune before I've even played it. I will tune the strings and by the time I've tuned the last one the rest have sharpened.
Any advice is appreciated.
Cheers
D4V3 is offline
post #2 of 2 (permalink) Old 01-17-2016, 07:57 AM
Re: Edge Zero 2 Problem
Follow Rich's guide here and you will be fine:
http://www.ibanezrules.com/tech/setup/tuning.htm
Mattww is offline
edge , problem , tremolo , tuning
Need help! Jem 7v edge problem scalelokt Ibanez JEM, UV, JS & Other Signature Models 8 08-05-2012 08:15 PM
edge pro problem. help? DanEwins Tech: Setup, Repairs and Mods 1 03-22-2009 01:40 PM
Edge Problem 560licious All Other Guitars (including Prestige) 2 03-23-2007 10:54 AM
Lo pro edge & Double Edge in tune problem Raffel Tech: Setup, Repairs and Mods 21 05-14-2004 09:59 AM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 02:43 PM
