Edge zero e standard tuning on heavier strings - Jemsite
post #1 of 9 (permalink) Old 10-04-2011, 04:51 PM Thread Starter
I have always played 9-42 strings, but recently thought heavier may sound better. I've bought 10-46 regular sliknies and my rg 2550z seems not to accept them. I'm trying to tune i e standard but even when I set the max spring tension bridge bends like I'm doing a slight dive bomb and action is like 3mm. Has anyone ever achieved the proper edge zero ballance and low action using heavier strings than 9-42 ?
Misza is offline
post #2 of 9 (permalink) Old 10-04-2011, 05:07 PM
Re: Edge zero e standard tuning on heavier strings
Hi, youŽll probably have to either, add an extra spring or, get higher tension (shorter) springs to accomadate the extra tension caused by the pull of higher gauged strings. I personally use 11-48 slinkies with 2 high tension and 2 normal tension springs and a german made trem setter, I can't remember the name of it after the beers I've had today....
Nelson
nsabino is offline
post #3 of 9 (permalink) Old 10-04-2011, 05:55 PM Thread Starter
unfortunately edge zero has only 2 spring slots. I'll think about higher tension springs. Anyone knows examples of tighter springs than stock edge zero ones ?
Misza is offline
post #4 of 9 (permalink) Old 02-01-2014, 02:54 AM
Hi yes I believe I am facing the same problem with my rg350. Where can I get heavier springs for my edge zero so I can run 10-46 strings?
How do you guys solve this problem when you run heavier strings on an edge zero II?
Atomant is offline
post #5 of 9 (permalink) Old 02-01-2014, 06:04 AM
I use 10-46 on my RG2550z with the original springs and it works fine.
Eskil is offline
post #6 of 9 (permalink) Old 02-01-2014, 08:08 AM
does it still flutter?
Atomant is offline
post #7 of 9 (permalink) Old 02-01-2014, 08:47 AM
seriously, I would rather ibanez would supply a different gauge tremolo springs than to crank up that thumb screw with the present stock tremolo springs with 10s gauge strings.
Atomant is offline
post #8 of 9 (permalink) Old 02-01-2014, 01:25 PM
Regarding the springs, I know that you can order higher tension springs for the zps system (this usally sits stock on 7 string guitars that have the zps).
As for the flutter, what do you mean by that?
Is it flutter as in when you hit trembar quickly and then the notes warble for a while or as in the bridge does tiny dives when you play hard?
Eskil is offline
post #9 of 9 (permalink) Old 02-01-2014, 01:45 PM
Part of the restriction of the ZPS unit was a lack of adjustability. There are 3 springs available, stock, 7 string, and EGEN, which I haven't figured out which of the later are higher tension.
Rich is offline
edge zero , gauge , heavy , strings
RGD in standard tuning? RG Loyalist All Other Guitars (including Prestige) 2 05-10-2011 11:29 PM
Buzzing issues after going to heavier strings? jestre700 Tech: Setup, Repairs and Mods 5 12-27-2010 06:33 PM
Heavier gauge, lower tuning - spring tension? Nesi Tech: Setup, Repairs and Mods 10 01-21-2007 10:39 AM
Drop sonic in standard tuning fredo Pickups & wiring 19 08-09-2006 07:57 AM
bridge ajustments with heavier strings KalleE_G All Other Guitars (including Prestige) 4 09-04-2004 02:56 PM
