Edge Zero II fix or replace ? - Jemsite
post #1 of 9 (permalink) Old 07-21-2018, 04:16 PM Thread Starter
Hey,
So I need some help. I recently got a Ibanez RG470MH from a friend who didn't need the guitar. The guitar was in bad shape. The pickups were f*cked, (neck pickup didn't work, so did the middle one) the only pick up that worked was the bridge and it sounded nasty. The tremolo system was broken also, one of the saddles was damaged. Honestly the whole guitar was a mess. But since I got a love for guitars, and the Ibanez felt amazingly good on my hands (the neck is great, slim but chuncky) I decided to restore this Ibanez, I know its a cheapo model, but I decided to give it some love.
Out with the old and in with the new, I took out the old pickups, bridge, pots, switch,and jack. Polished the frets, polished the neck, took care of the body, covered the single coil slot. Ordered a set of SD nezgul and sentinent set, new electronics.
But here's the problem, I need a new bridge, wanting something a little nicer than the EZII, I was thinking a OFR or a Lo-Pro/Edge Pro, I saw a post here of a guy who changed a EZ to a Edge Pro, I know this involves some wood work, which I have a luthier who can do it. But my question is, is it worth doing it ? Or just try and fix the EZII and go from there ?
Thanks !
EDIT: Here are some pics of the guitar itself : https:// imgur.com/a/umKKOIe
idcboutthis is offline
post #2 of 9 (permalink) Old 07-21-2018, 06:01 PM
Re: Edge Zero II fix or replace ?
The EZII really isn't that bad, for the price of a new saddle it's worth fixing up.
sepulchrave is offline
post #3 of 9 (permalink) Old 07-21-2018, 06:30 PM
It's cheap, but so is the EZ that's on J Customs. In the end stability is all that's really important and it's a very stable trem.
Rich is offline
post #4 of 9 (permalink) Old 07-21-2018, 06:33 PM Thread Starter
Okay Thanks ill keep the EZII then and fix the saddles. But if I cant manage to fix it, what do you recomend for a bridge ?
post #5 of 9 (permalink) Old 07-21-2018, 06:37 PM
Why wouldn't you be able to fix the saddles?
Rich is offline
post #6 of 9 (permalink) Old 07-21-2018, 06:44 PM Thread Starter
The saddles I can order and 'fix' but idk, the bridge it self looks a bit damaged and it seems like it will break anytime soon
post #7 of 9 (permalink) Old 07-21-2018, 06:46 PM
Perhaps photos of the stuff that's damaged rather than the bits that aren't would be more helpful?
post #8 of 9 (permalink) Old 10-09-2018, 08:46 PM
Must be pretty severe to be damaged. only a hefty smack into the middle of the bridge with a hammer would damage the plate and sustain block, or your friend thought he was Pete Townshend.
Each saddle is individually replaceable and not expensive.
You could order a complete bridge for less than 6 saddles.
Without pics though - the point is moot. Noone other than you can assess the extent of the damage unless we can see it.
JB74 is offline
post #9 of 9 (permalink) Old 10-09-2018, 08:51 PM
A used bridge or one out the back door of Cort Indo bought from Indonesia. The cost of the bridge is in the $270 range. A complete saddle is $32.
Rich is offline
Can Edge Zero II fit in Edge Zero cavity? bancika All Other Guitars (including Prestige) 2 05-11-2018 10:57 AM
Edge zero II arm holder fix guitar2be Tech: Setup, Repairs and Mods 2 11-30-2016 07:16 PM
Replacing Edge Zero ii with Edge Zero rmelancon1432 Tech: Setup, Repairs and Mods 25 05-02-2016 07:30 AM
Replacing edge zero with edge zero II? Ansio Tech: Setup, Repairs and Mods 14 11-19-2015 01:08 AM
Edge zr, zero, zero ii xxgdkxx All Other Guitars (including Prestige) 9 12-28-2011 09:17 PM
