Edge zero stud odd problem - Jemsite
post #1 of 2 (permalink) Old 09-15-2015, 04:26 PM Thread Starter
I just got a new to me RG style J custom with an edge zero and zero point system. I'm trying to set the action height and it seems like the studs don't want to go any lower. There are no set screws in the studs.. They just feel like they bottom out and the action is still pretty high. Any thoughts? I guess I'm going to remove the trem so I can take a closer look. Let me know if you guys have any ideas.
Tahoebrian5 is offline
post #2 of 2 (permalink) Old 09-15-2015, 07:57 PM
Re: Edge zero stud odd problem
Are you absolutely certain there's no set screws inside the studs?
How Low is "low"? I can bury mine so it sits almost* flush with the body (inside the cavity), With the Intonation alignment tool being basically same height as the paint. However it's an RG so perhaps there's differences I know nothing about
You could also consider changing the angle of the neck (shim the neck pocket) to help with your action, the Trem shouldn't need to be buried too far into the body that way.
Leeroy_Majors is offline
wtb - black edge trem stud and edge lo pro 7 cosmo jrojas159 Classified Ads: Guitars and Gear 2 05-28-2012 11:22 PM
Edge stud problem! Mister CCJ Tech: Setup, Repairs and Mods 1 08-04-2007 11:57 PM
Edge PRO stud mod.... rya Ibanez JEM, UV, JS & Other Signature Models 18 10-24-2006 08:52 PM
Stud set screw problem MichalD Tech: Setup, Repairs and Mods 2 07-25-2003 09:56 AM
problem with my stud inserts!Help jemke Tech: Setup, Repairs and Mods 15 11-21-2002 09:18 AM
