Edge Zero with ZPS3 - Jemsite
post #1 of 2 (permalink) Old 04-14-2017, 04:09 PM Thread Starter
Edge Zero with ZPS3
Hey everyone!
I got a 2120Z with a Edge Zero with ZPS3 and Im having soem trouble getting the bridge level. With the ZPS3 at full tension the bridge still isn't quite level.
Opendome is offline
post #2 of 2 (permalink) Old 04-14-2017, 04:14 PM
Re: Edge Zero with ZPS3
The angle of the trem with the ZPS bar engaged is set by the bar/block mate, and the trem will often be at an angle.
ZPS setup
With the bar touching the trem block, the first movement of the trem in a dive, the block moves away from the bar, the bar does not move. First movement doing a pullup, the bar moves with the trem block, there is no lag.
On some guitars the trem angle is dead flat with the ZPS set correctly, taking the ZPS out will only change the tuning and trem angle a hair as the tension is preloaded a little bit from the bar against the block. On some guitars the ZPS will be in a slightly different spot and the trem angle will not be perfectly flat with the ZPS set correctly. If you take the ZPS out the tuning and trem angle will need adjusting as before, but trem angle will need to be set perfectly flat, which will not change the action because the action was set with the ZPS in, without flat trem angle.
Rich is offline
rgd2120z
Edge Zero II w/zps3 Trem swap? Venice Tech: Setup, Repairs and Mods 10 07-30-2014 03:34 PM
Edge zero zps3 to a zps-fx Yianni54 Tech: Setup, Repairs and Mods 6 02-02-2014 06:20 PM
RG3520ZE Edge zero with ZPS3 Yianni54 Tech: Setup, Repairs and Mods 6 02-02-2014 12:47 PM
question about adjusting the action on an Edge Zero II (with ZPS3) Santuzzo Tech: Setup, Repairs and Mods 2 02-08-2013 03:06 PM
Replace Edge Zero ZPS3 to Lo pro Edge raflemos All Other Guitars (including Prestige) 12 06-14-2012 10:39 PM
