edge zero2, high action - Jemsite
post #1 of 12 (permalink) Old 10-20-2014, 04:39 AM Thread Starter
I want to lower the string action on my Premium 920QM, I think it has the Edge Zero 2 system.
I lowered the stems already, but it is not enough. What is next, do I need to use the thumb screw on the back?
I guess I would like to get higher tensions on the springs in the back?
Olwdillchips is offline
post #2 of 12 (permalink) Old 10-22-2014, 04:44 AM Thread Starter
Re: edge zero2, high action
Anyone knows?
I want to lower the string action, and I have already lowered the stems, cannot lower it any further, what is the next step?
post #3 of 12 (permalink) Old 10-22-2014, 06:04 AM
Maybe check the neck relief and other things listed on the tech page of ibanez rules.
alecmm61 is offline
post #4 of 12 (permalink) Old 10-22-2014, 11:16 AM
Did you loosen the stud-locks before you lowered the 'stems' (studs)?
I'm pretty sure the EZ II has stud-locks. If you didn't, that's most likely why you can't lower them any further
www.ibanezrules.com is a great place for setup info, or the manual that should have come with the guitar.
Meechy is offline
post #5 of 12 (permalink) Old 10-22-2014, 12:16 PM
Definitely the stud locks.
panix is offline
post #6 of 12 (permalink) Old 10-24-2014, 09:13 PM
Stud locks.
Archer250 is offline
post #7 of 12 (permalink) Old 10-25-2014, 03:08 AM
oops..
yzerman is offline
post #8 of 12 (permalink) Old 10-25-2014, 03:20 AM Thread Starter
I tried to insert the thin key into the studs, but it does not hook at all. Does it really have stud locks?
I tried on my other guitar which has Original Edge, and when inserting the thin key, it hooks immediately
post #9 of 12 (permalink) Old 10-25-2014, 03:25 AM
2mm allen.
Rich is offline
post #10 of 12 (permalink) Old 10-25-2014, 05:06 AM Thread Starter
Originally Posted by Rich View Post
2mm allen.
Thnx now it works.
Are you sure it is the 2 mm though, this allen seems thicker than the one used for Original Edge?
post #11 of 12 (permalink) Old 10-25-2014, 10:42 AM
RGTFanatic's Avatar
It should be thicker. The locks on the original edge use a 1.5mm
RGTFanatic is offline
post #12 of 12 (permalink) Old 10-30-2014, 02:02 AM Thread Starter
Ok, makes sense
action , edge zero , premium 920qm , string
Jem 7v Action to high help! eatsleepplayguitar Ibanez JEM, UV, JS & Other Signature Models 31 10-10-2007 08:09 PM
High Action waylay00 Tech: Setup, Repairs and Mods 45 07-21-2007 03:56 PM
high action or just me? marshall Ibanez JEM, UV, JS & Other Signature Models 4 12-16-2003 08:38 AM
High action - what else can I do?? yurich Tech: Setup, Repairs and Mods 3 03-12-2002 10:12 PM
Action...how high or low? - where do you like diek Tech: Setup, Repairs and Mods 7 11-04-2001 10:31 PM
