Edge3 Replacement Tremolo (no mod-free upgrade except EdgePro) - Page 28 - Jemsite
 4Likes
post #406 of 408 (permalink) Old 05-25-2020, 09:18 PM
Re: Edge3 Replacement Tremolo (no mod-free upgrade except EdgePro)
The only complaint that's real is the cost of the replacement bushings. If you want to bitch about that I'd be by your side. Otherwise, there is no problem with the push in setup if you know what you're doing, and the bushings will last a long time if handled right.
Rich is offline
post #407 of 408 (permalink) Old 10-29-2020, 01:39 PM
I've replaced an edge 3 with an ofr and it won't return to pitch after using the trem arm. It goes ever so slightly sharp if I sharpen the notes and returns to normal pitch if I flatten the notes!
I'm thinking it's the original edge 3 bridge posts/studs that are the issue because the ofr is brand new!
Any advice on what to do or where to buy a better non-invasice replacement would be appreciated!
dylanjenova is offline
post #408 of 408 (permalink) Old 10-29-2020, 08:41 PM
Reviews: 120
I think I recall in this chat or another one about the Edge III, that someone found maybe the schaller posts fitted the Edge III bushings. It may be worth doing a search around the forum. It was some time ago though.
LonePhantom is offline
base plate , floyd rose , floyd rose pro , ibanez dealer , lopro trem , neck shim , pro edge , schaller trem , string lock
Replacement Edge parts? Upgrade? Superlead777 Tech: Setup, Repairs and Mods 1 01-15-2015 08:33 PM
Anyone mod/upgrade their trems? Grimlord All Other Guitars (including Prestige) 5 03-07-2013 11:03 PM
Edge3 ARM swap OFR arm upgrade 2DECADESSOFAR Tech: Setup, Repairs and Mods 17 06-23-2012 10:52 PM
JS 100 Tremolo Upgrade? Monsta-Tone Ibanez JEM, UV, JS & Other Signature Models 1 02-05-2012 07:32 PM
Mod ideas - i have a pot free one less than none Tech: Setup, Repairs and Mods 3 07-05-2001 04:03 PM
