Edge3 Replacement Tremolo (no mod-free upgrade except EdgePro) - Page 4 - Jemsite
 4Likes
post #46 of 408 (permalink) Old 02-04-2008, 05:48 AM
re: Edge3 Replacement Tremolo (no mod-free upgrade except EdgePro)
hello
i have here a ibanez proline/rg with a floyd rose ll ,i think all original(the first owner couln't chance the trem(not even the strings hahaha (joke)look at the picture.
http://img180.imageshack.us/my.php?i...oydrosexv3.jpg
brianxtr is offline
post #47 of 408 (permalink) Old 02-04-2008, 06:43 AM
So, edge pro then..?
pera_a777 is offline
post #48 of 408 (permalink) Old 02-25-2008, 05:13 AM
Reviews: 13
I have a 2002 RG370 will an Edge Pro, Edge III or Edge Pro II fit? This is all doing my head in!
-Wolfram
Wolfram is offline
post #49 of 408 (permalink) Old 02-25-2008, 07:02 AM
Reviews: 4
Will it add anything up to this discussion if I say that I fitted my RG470 with an OFR Pro?...
Crazy_Guitar is offline
post #50 of 408 (permalink) Old 02-29-2008, 10:45 PM
So can you retrofit a lo-pro into an edge pro route if you sand down the wings about an 1/8 of an inch? of will the tail of the trem be a problem also?
ChaosAndOrder30 is offline
post #51 of 408 (permalink) Old 03-07-2008, 05:48 AM
-Wolfram
My head is spinning too... My take-away from all this is that the Edge Pro is a direct replacement for the Edge III in all those cheap RG models like RG350.
85db is offline
post #52 of 408 (permalink) Old 04-16-2008, 02:53 PM
I've got another combination:
I've bought an older RG body, which has the routing for an edge or lo-pro edge. Now my question is: Will an edge pro II retrofit this routing?
Btw. the body hasn't arrived yet ;-)
Thx
FoneBone
FoneBone is offline
post #53 of 408 (permalink) Old 04-18-2008, 11:52 AM
Thx
FoneBone
It DOESN'T retrofit!!!!
FoneBone is offline
post #54 of 408 (permalink) Old 07-20-2008, 12:48 PM
So choices to replace an Edge III are either an Edge Pro or an OFR?
Would be nice to know before forking out for a replacement bridge.
Deepsquirrel is offline
post #55 of 408 (permalink) Old 07-20-2008, 10:52 PM
Deep, The Edge Pro doesn't retrofit the Edge III cavity, your best bet is the Original Floyd Rose.
Ryan350DX is offline
post #56 of 408 (permalink) Old 07-20-2008, 11:48 PM
Reviews: 120
That's interesting, a number of people have said that the Edge Pro DID fit the Edge III cavity.
LonePhantom is offline
post #57 of 408 (permalink) Old 07-21-2008, 04:56 AM
the EdgePro DOES retrofit the Edge-III:
while the Floyd Rose (and Schaller Floyd as well) does NOT retrofit:
(check the wrong knife-to-post relationship)
nuno is offline
post #58 of 408 (permalink) Old 07-21-2008, 05:11 AM
i had the chance to make some trem-to-cavity fitting experiment lately and i ended up with the following results:
on IBANEZ EDGE-III cavity:
• Ibanez Edge into Edge-III cavity: NO
• Ibanez Lo-Pro Edge into Edge-III cavity: NO
• Ibanez Edge-Pro into Edge-III cavity: YES
• Original Floyd Rose into Edge-III cavity: YES
• Schaller Floyd Rose into Edge-III cavity: NO
on IBANEZ EDGE/LoPro EDGE cavity:
• Original Floyd Rose into Ibanez Edge/LoPro Edge cavity: YES
• Ibanez Edge-Pro into Ibanez Edge/LoPro Edge cavity: YES
on IBANEZ EDGE-PRO/EDGE-PRO II cavity:
• Ibanez Edge into Ibanez Edge-Pro/Edge-Pro II cavity: NO
• Ibanez Lo-Pro Edge into Ibanez Edge-Pro/Edge-Pro II cavity: NO
• Original Floyd Rose into Ibanez Edge-Pro/Edge-Pro II cavity: YES
• Schaller Floyd Rose into Ibanez Edge-Pro/Edge-Pro II cavity: NO
on Original FLOYD ROSE cavity:
• Ibanez Edge into Original Floyd Rose cavity: YES
• Ibanez Lo-Pro Edge into Original Floyd Rose cavity: YES
check pics HERE. sorry, italian only, but pics pretty much explain themselves
*EDIT*
gotta update the above compatibility list as to avoid readers to take wrong references.
*EDIT 2*
converted aspx to html
jim777 likes this.
Last edited by nuno; 12-12-2008 at 04:24 AM. Reason: references updating + aspx to html conversion
nuno is offline
post #59 of 408 (permalink) Old 07-21-2008, 11:20 AM
Has the Edge III cavity changed over the years? or has it remainded the same?
post #60 of 408 (permalink) Old 07-21-2008, 06:42 PM
I won't be needed to put a new tremolo in after all
Managed to get a preowned Prestige RG1570 (edge pro already in there obviously) for 215, only around 50 more than i would have ended up paying for an OFR or an edge pro anyway! (replacement stuff is more expensive over here)
base plate , floyd rose , floyd rose pro , ibanez dealer , lopro trem , neck shim , pro edge , schaller trem , string lock
Replacement Edge parts? Upgrade? Superlead777 Tech: Setup, Repairs and Mods 1 01-15-2015 08:33 PM
Anyone mod/upgrade their trems? Grimlord All Other Guitars (including Prestige) 5 03-07-2013 11:03 PM
Edge3 ARM swap OFR arm upgrade 2DECADESSOFAR Tech: Setup, Repairs and Mods 17 06-23-2012 10:52 PM
JS 100 Tremolo Upgrade? Monsta-Tone Ibanez JEM, UV, JS & Other Signature Models 1 02-05-2012 07:32 PM
Mod ideas - i have a pot free one less than none Tech: Setup, Repairs and Mods 3 07-05-2001 04:03 PM
