@Yanic: nuno's pics earlier in this thread suggest that upbendings should be no problem with an OFR in an Edge III cavity. At any rate, I wouldn't route anything before I hold the thing in my hands and see whether there is actually a problem.
Has anyone experience with drilling out the Edge III anchor holes to fit in the larger Edge Pro inserts? I'd like to know how risky this business is, before I decide whether I want to try it. What diameter should the holes be, so that the new inserts fit tightly? Many thanks!
yes i did that mod to my crapy 350 dx
here is the way that this mod
1-remove the plastick thing from the ancours-and then remove the screws
2-put in the orginals studs to the anchours and try to force to get it out from studs(hould the studs with a pense or something strog)..because its the only safe way to get them
3-if it(second step) does not work---find one of the anchours is near the back tremolo cavity.i explain this because you have to drill with a 2 mm drill from back of the ancour.and with a small screw driver and litle hammer you have to hammer and get the one of the anchour out..if it goes litle far to away you will able to to get it out easyly
4-you have to drill the anchour post with a litle bit small diameter drill and then litle finish work with a sanding papper inside the holes
5-take in the new anchours in side the holes an then litle force with a hammer and dont forget to take a piece of rubber on the new anchour...
6-same job to the other anchour and wallaaaaa----
one of my friend asked if anybody paint the trems???
no due
no way
forget about it because there is no paint on it.there is special hot electrolise cover on it.so it can not paint
anyway if you that 3-4 days later it will worn out
