Edge3 Replacement Tremolo (no mod-free upgrade except EdgePro) - Jemsite
 4Likes
post #1 of 408 (permalink) Old 09-18-2007, 02:22 PM Thread Starter
I have an Edge3 Tremolo on one of my guitars and I want to replace it with something else. It's horrible and is tarnished and never stays in tune. I don't really want to shell out on another OFR, but I was thinking a really good licensed Floyd Rose would be good. Can anybody reccommend me something?
digitalsubstance is offline
post #2 of 408 (permalink) Old 09-18-2007, 05:55 PM
Dee
re: Edge3 Replacement Tremolo (no mod-free upgrade except EdgePro)
Schaller, Gotoh, Ping. Those are 3 of the makes that I would look at.
Dee is offline
post #3 of 408 (permalink) Old 09-18-2007, 10:17 PM
Reviews: 120
Gotoh all the way.
LonePhantom is offline
post #4 of 408 (permalink) Old 09-19-2007, 03:42 AM
Gotoh or OFR hands down.
thrill74 is offline
post #5 of 408 (permalink) Old 09-19-2007, 03:56 AM
you must know first that ANY other trems except the Edge-Pro and Edge-Pro II will require routing works on the cavity to accomodate.
nuno is offline
post #6 of 408 (permalink) Old 09-19-2007, 05:56 AM
gotoh will fit the edge 3 rout. its affordable compared to the rest of the brands.
slash_88 is offline
post #7 of 408 (permalink) Old 09-19-2007, 06:35 AM
you tried it? i did, and it didn't fit.
nuno is offline
post #8 of 408 (permalink) Old 09-19-2007, 08:26 PM
Reviews: 120
If it doesn't fit I'm sure there's just a little bit of sanding (or dremmel to speed up the process if you have one) around the cavity to fix it.
post #9 of 408 (permalink) Old 09-19-2007, 09:25 PM
I've done an OFR replacement to a 350EX that was a direct drop in. Same thing with an LTD M-400, but that's a different story all together.
thrill74 is offline
post #10 of 408 (permalink) Old 09-19-2007, 10:11 PM
PING
Hands down, the best OFR copy out there. In fact, it's the only LFR to bear the Floyd Rose logo on it's baseplate.
I can attest to it's durability, I own one.
Salamander In The Sun is offline
post #11 of 408 (permalink) Old 09-19-2007, 11:21 PM
isn't the edge 3 rout the same as the edge pro 11? because your earlier post said the edge pro 2 and edge pro doesnt need routing work to retrofit an edge 3 rout. so im assuming the edge pro 2 and edge 3 sizes are the same. and my gotoh i used retrofitted mi edge pro 11 rout easily. so it should go in unless the edge 3 rout is smaller.
slash_88 is offline
post #12 of 408 (permalink) Old 09-20-2007, 03:52 AM
yep, but somehow you can't do vice versa. unluckily i forgot to take pics when i tried to fit a Gotoh in an Edge-III rout but i took one with a Schaller Floyd, which is exactly the same shape and dimensions of the Original Floyd and the Gotoh as well. it would fit dimensions-wise, but the post holes are moved too backward for the Gotoh knives to fit in. take a look...
Edge-Pro into an Edge-III rout: it fits.
Schaller (Gotoh) Floyd into an Edge-III rout: it doesn't fit.
nuno is offline
post #13 of 408 (permalink) Old 09-20-2007, 03:55 AM
what year? i.e. what trem there was in?
nuno is offline
post #14 of 408 (permalink) Old 09-20-2007, 04:34 AM
ar i see thanks for the insight nuno. interesting and edge pro can fit and edge 3 rout. by the way nuno is an edge able to fit a edge pro rout? just curious to know.
slash_88 is offline
post #15 of 408 (permalink) Old 09-20-2007, 06:19 AM
unluckily no. the back side of the "wings" would rock against the cavity, and the string lock screws as well. take a look...
Edge into Edge-Pro cavity (JS1200CA): no fit
same thing with the Lo-Pro:
Lo-Pro into Edge-Pro cavity (JEM7VSBL): no fit
nuno is offline
base plate , floyd rose , floyd rose pro , ibanez dealer , lopro trem , neck shim , pro edge , schaller trem , string lock
Replacement Edge parts? Upgrade? Superlead777 Tech: Setup, Repairs and Mods 1 01-15-2015 08:33 PM
Anyone mod/upgrade their trems? Grimlord All Other Guitars (including Prestige) 5 03-07-2013 11:03 PM
Edge3 ARM swap OFR arm upgrade 2DECADESSOFAR Tech: Setup, Repairs and Mods 17 06-23-2012 10:52 PM
JS 100 Tremolo Upgrade? Monsta-Tone Ibanez JEM, UV, JS & Other Signature Models 1 02-05-2012 07:32 PM
Mod ideas - i have a pot free one less than none Tech: Setup, Repairs and Mods 3 07-05-2001 04:03 PM
