ESP Arming Adjuster and RG2550EGK - Jemsite
post #1 of 9 (permalink) Old 12-19-2005, 12:57 PM Thread Starter
I was wondering if anyone know if the ESP Arming Adjuster would fit on the 2005 Ibanez RG2550EGK. If anyone didn't know it has an edge pro trem.
I was trying to find out if it will work before i get the ESP
KrazyKris24 is offline
post #2 of 9 (permalink) Old 12-19-2005, 06:20 PM Thread Starter
Re: ESP Arming Adjuster and RG2550EGK
Or can someone tell me if the ESP will fit any of the new RG's or anything with an edge pro
post #3 of 9 (permalink) Old 12-20-2005, 02:04 PM
We had a discussion on this subject a while back:
http://www.jemsite.com/forums/showthread.php?t=41874
I seem to remember there was another thread, but I can't find it right now.
Awakened Sleeper is offline
post #4 of 9 (permalink) Old 12-20-2005, 02:57 PM
The ESP Arming Adjuster works fine with the OFR/EDGE/LO-PRO/Edge pro. Got one installed in all my guitars, and I have one on all four types of bridges. All of them work fine. Seeing that I did that review of that ESP Arming Adjuster here and probably the only one that has the arming adjuster installed in guitars with all four of the prominent trems, I'm pretty sure that I can guarantee you that it'll work fine.
(Some routing needed to be done on my guitars but I've installed the arming adjuster for others who didn't want to get thier cavities routed. It just had to be installed a little further out)
buddroyce is offline
post #5 of 9 (permalink) Old 12-20-2005, 03:25 PM Thread Starter
aight thanks, depending on how much it will cost at my local music shop to route i'll do that but if not i'll just install it
post #6 of 9 (permalink) Old 12-20-2005, 05:51 PM
it's VERY little routing.
In fact basswood(the body wood on the RG2550EGK) is so so soft that I actually routed the space I needed using a knife(no joke here). Just score and cut out the shape you need(either a semi circle or a square) and then just chisel it out. (I had to do it once when my router wasn't working and I didn't have my dremel with me.. had to do it the old school way).
Most places would probably charge like $20 to do. I would actually find someone that's got a dremel with a router base to do it for you, it's less of a hassle and you can probably get away with it for a coffee or something.
Cheers,
Budd
post #7 of 9 (permalink) Old 12-20-2005, 09:02 PM Thread Starter
Yea that sounds pretty easy but at 15 i'll probably get my dad to do it, but i think his friend has a dremel cause he's has like a hardware store for a garage
post #8 of 9 (permalink) Old 12-20-2005, 09:19 PM
In that case it'll be cheap for you. There isn't much to route out anyway.
post #9 of 9 (permalink) Old 12-20-2005, 11:06 PM Thread Starter
OK , thanks for the help
edge pro trem , esp arming adjuster , local music shop
zps or ESP arming adjuster? floydprofan Tech: Setup, Repairs and Mods 0 02-20-2009 04:31 AM
ESP Arming Adjuster charliet Ibanez JEM, UV, JS & Other Signature Models 2 06-08-2008 10:34 AM
ESP Arming Adjuster? Ripkord Tech: Setup, Repairs and Mods 6 07-13-2007 06:43 PM
ESP Arming Adjuster Entropy Tech: Setup, Repairs and Mods 6 10-05-2006 02:55 PM
ESP Arming Adjuster thebigugly All Other Guitars (including Prestige) 3 01-25-2006 03:16 AM
