Experiences with different string gauges on edge-guitars - Jemsite
post #1 of 2 (permalink) Old 08-20-2002, 05:10 AM Thread Starter
Hi there,
18 month ago I switched string gauges on my Edge-Equipped Radius (from 9 to 10). Now I am planning to go on to 11.
Following questions:
What string gauges got you on your guitar (well, at least those having a floyd-rose-like bridge)
During bendings I made the experience that I pull my edge-tremolo (just with the strings). Is this normal, due to the strings gauge or do I have to consider more about the setup (neck"tension")?
And yes, I followed Ibanez FAQ when I changed from 9 to 10.
Thanks,
Lenny
LennyNero is offline
post #2 of 2 (permalink) Old 08-20-2002, 06:25 AM
dex
If you don't want to pull your trem out when bending, you should get a tremsetter.
Otherwise it is normal for the floating tremolo to come up when you bend, esp. if you bend to achieve more than a full tone change.
I quite like the fact that the trem gives if you bend a lot, because it makes bending easyer.
Also you don't put as much strain on the strings as you would with a tremsetter or a fixed bridge.
Hope that helps.
dex is offline
fixed bridge , floating tremolo , string gauges
Air Travel - What Are Your Experiences Travelling With Guitars GoodVaibes Off-topic / Miscellaneous 11 11-22-2013 03:52 AM
ET-Guitars (Experiences) Norstorm All Other Guitars (including Prestige) 34 03-27-2012 09:02 AM
Different string gauges for different guitars? RemyL Ibanez JEM, UV, JS & Other Signature Models 0 05-07-2011 12:29 PM
Do you guitars have different string gauges? Silverburst Polls 24 01-26-2009 10:54 AM
String gauges NeglectedField All Other Guitars (including Prestige) 21 10-31-2006 10:09 PM
