Exposed Coil Humbucker's - How would this sound on my FP? - Jemsite
post #1 of 4 (permalink) Old 12-16-2000, 11:33 AM Thread Starter
Just for shats and giggles, I was wondering if anyone has ever tried taking that ribbon off the pick-ups, to expose the coils. I know Gisbon does this with their Gothic series guitars, and it says it gives the guitars a wicked sound...so even though they are probably just blowing smoke up their own asses, has anyone ever tried this?
Thanks!
Andy J Dampier is offline
post #2 of 4 (permalink) Old 12-16-2000, 02:23 PM
I don't think the ribbons do anything but hide the copper windings. It's purley cosmetic. It's just a strip of nylon glued to the pickup. If you want to expose your windings:biggrin:, I won't look.....hehehe.
J>
Vaibanez is offline
post #3 of 4 (permalink) Old 12-18-2000, 02:22 PM
Actually, it probably protects the windings as well. AFAIK, pup winding is usually done w/ wire coated w/ laquer or shellac, anyway, some thin, fragile substance with a high dialectric constant as an insulator. The benefit is that the insulation is thin, so you can pack more winding in the same space for a hotter pup (same is true for transformers and motor windings). BUT, if you chip it *(the insulation) you'll get shorts and you're off to buy a new pup.
FWIW,
-bill
wyldbill is offline
post #4 of 4 (permalink) Old 12-18-2000, 04:04 PM
Gibson writes:
“Exposed coil pickups ensure an equally wicked sound.”
I think they're referring to the fact that these pickups don't have Gibson's customary nickel covers over the bobbins.
They should have written “exposed bobbin pickups.” I don't think they're saying that they've removed the protective ribbon from the actual coil windings.
As wyldbill suggested, that'd be rather foolish.
darren wilson is offline
coil pickup
FS/FT Single coil and humbucker Cameron1234 Classified Ads: Guitars and Gear 0 12-26-2012 05:04 AM
humbucker in single coil space graaf33 Pickups & wiring 1 03-02-2011 04:59 PM
Looking for a humbucker that has good split coil sound on neck position. Alan0354 Pickups & wiring 6 02-17-2011 05:29 AM
Coil tap the bridge humbucker? Possible? Blacksunshine Ibanez JEM, UV, JS & Other Signature Models 5 11-24-2008 10:17 AM
converting humbucker to split only one coil ubertwerp Pickups & wiring 3 11-26-2006 12:53 AM
