Feel of LoPro Edge 7 vs LoPro Edge 6 and other setup issues - Jemsite
post #1 of 10 (permalink) Old 04-15-2003, 02:43 PM Thread Starter
Question:
Is it just that my setup is incorrect, or does a LoPro Edge 7 feel really different than the six string version? I remember when a friend of mine has a Petrucci model, the bridge moved so easily and smoothly...Mine does NOT at all...I also have this sorta 'clunka-clunka' sound near the floating point of the bridge..can't really do subtle things..
Re: bridge height...the posts on both side should be at exactly the same height correct?
Re: bridge angle...Realistically where should I set it? I can either get it so that dive bombing is easy, but it dumps all really quick..Or I can get it to where I can pull up a bit, but it frets out at the end of travel...
Suggestions please!
If I cant get this to work with a nice new set of strings, and some patience, I'm giving up on this, and bringing it somewhere.
Help Please. :-/
-Matt
mdrobnak_rg7 is offline
post #2 of 10 (permalink) Old 04-15-2003, 06:16 PM
For the clunking noise, check the tightness of the arm holder, and then replace the hite nylon bushings. One of those two oughta do it.
Due to the added string tension of the low B, a LopPro 6 will definately feel looser than a 7.
-Drew
Drew is offline
post #3 of 10 (permalink) Old 04-15-2003, 06:38 PM
Is there any way to remove that clunking you get with no bushings on? (for sloppy bar play)
Jeff is offline
post #4 of 10 (permalink) Old 04-15-2003, 08:34 PM
No bushings will put it directly metal-to-metal, a fine recipe for even more clunking.
I'd have to say that's just not a good idea. The only thing I can think of is to use something like super-fine sandpaper or similar to take off some of the bushings' thickness, testing often, until it swings as easily as you like, and yet minimizing the metal-to-metal contact.
steve is offline
post #5 of 10 (permalink) Old 04-15-2003, 09:30 PM
I've found that just pushing the bar in and out a lot will do the same thing.
After a week or two of pulling it out three or four times a day my bars swing free.
Personally I like them to stay put, and there's another thread somewhere that I asked for some help with this.
Mic
MicJustMic is offline
post #6 of 10 (permalink) Old 04-16-2003, 12:45 AM
You can also lube it up with some 2 in 1 oil so that although the nylon bushings might still be exerting pressure against the inner wall of the arm holder, the bar swings freely inside the bushings. In other words, bushings stay put, arm swings. That way you'd still have noise reducing tension. The other thread mentions the Schaller type arm holder. It is great for tight tension, but the tolerances are usually pretty tight, so that even if you set it to swing loosely, the arm fits perfectly in the holder so you'd get a good feel on the up and down.
frankfalbo is offline
post #7 of 10 (permalink) Old 04-16-2003, 01:17 AM
Sometimes you'll get a new one that has so much [extra] grease in the holder a new bar won't stay where you put it [after the gorrila slams it into the hole because that's always the most fun on a new bar]
Rich is offline
post #8 of 10 (permalink) Old 04-16-2003, 03:01 PM
Okay, you lost me on that one Rich . . .
Mic
post #9 of 10 (permalink) Old 04-16-2003, 03:05 PM
You ever try to get a new bar into a new guitar?
Rich is offline
post #10 of 10 (permalink) Old 04-16-2003, 03:56 PM
Ah yes, okay . . . NOW I get it. (I'm a little slow today)
I have a total of 10 (yes boys and girls, TEN) bars for two guitars at this point . . . so I've put them in new ones, old ones, new bars old guitars . . . so on, so on.
Yep, always a little shove is needed on those virgin bars/guitars.
Mic
arm holder , bridge angle , petrucci model , pro edge , string tension
PICS Edge LoPro and neck setup questions S540 '93 is this right? ErickMoral Tech: Setup, Repairs and Mods 27 06-14-2013 09:09 AM
WTB: square heel neck and edge/lopro edge needed nafigator Classified Ads: Guitars and Gear 0 03-27-2011 06:41 PM
FS/FT Gold LoPro Lo-Pro Lo Pro Edge for original Edge mechanyx Classified Ads: Guitars and Gear 12 12-23-2010 04:25 AM
Can you replace an edge trem with a LoPro Edge? - Is it poss Cycovision Tech: Setup, Repairs and Mods 7 05-16-2009 01:22 AM
Is the LoPro Edge easily swappable with the Edge? agquake Tech: Setup, Repairs and Mods 1 06-20-2003 02:10 PM
