Fine tuner problem on Edge Lo Pro - Jemsite
post #1 of 10 (permalink) Old 11-10-2009, 07:13 PM Thread Starter
Hey guys,
Just bought a used BSB. Having an issue with the fine tuner on the D string though. It seems as though the string lock screw (the screw you tighten with the allen wrench after putting a new string in) has been replaced because it is a different color.
The issue is that the fine tuner becomes extremely difficult to tighten (raise the pitch) once you reach a certain point.
What could be the cause of this?
Thanks,
Jeff
Lifeson22 is offline
post #2 of 10 (permalink) Old 11-10-2009, 07:14 PM Thread Starter
Re: Fine tuner problem on Edge Lo Pro
To clarify.....
After the guitar has been restrung and the nut is locked down, the fine tuner is extremely difficult to turn once you reach a certain point.
post #3 of 10 (permalink) Old 11-10-2009, 07:56 PM
jb4674's Avatar
Reviews: 18
Order a new saddle from Rich or replace the trem altogether with a new one.
Jimmy
jb4674 is offline
post #4 of 10 (permalink) Old 11-10-2009, 08:32 PM
Ayrton's Avatar
I am not sure what the string lock screw has to do with the fine tuner.
Remove the fine tuner screw and check the threads. Is the screw easy to turn and then tightens up at the same point? If so then there may be damaged threads.
Try swapping out that fine tuner with another to see if it is the screw or the plate.
Ayrton is offline
post #5 of 10 (permalink) Old 11-10-2009, 08:45 PM
Originally Posted by Lifeson22 View Post
To clarify.....
Assuming the fine tuner hasn't bottomed out naturally, here's a systematic approach:
-Is the replaced string lock screw too long and hitting the trem base plate? This should be easy to spot.
If not, then:
-Is the trem level? If it is tilted back, your saddle pipe might be hitting the trem cavity.
-If the above is not the problem, with the string loose, does the pivoting part of the saddle have the same range of motion as the other saddles? Make sure there isn't something jammed between the pivoting part of the saddle and the base plate.
- If the above is not the problem, can you turn the fine tuner through its full range with the string loose (i.e. not adjusted to pitch)? If not the threads on the fine tuner may be stripped.
This is off the top of my head, let me know if it is none of the above.
nlinny is offline
post #6 of 10 (permalink) Old 11-10-2009, 09:42 PM Thread Starter
I will try some of these ideas out....
Just by looking, i can tell that the screw looks like it might be a different length than the rest of the screws. But it looks shorter than the others (as in closer to the neck).
Thanks
post #7 of 10 (permalink) Old 11-10-2009, 09:45 PM Thread Starter
Just did a quick test and loosened the D string......with the string completely loosened, i still can't turn the fine tuner the entire way. It reaches a certain point while you tighten it and then you can't turn it anymore (a little more than halfway)
post #8 of 10 (permalink) Old 11-10-2009, 09:51 PM
Is that saddle in a drastically different position, or about the same spot as the A saddle?
Rich is offline
post #9 of 10 (permalink) Old 11-10-2009, 09:53 PM Thread Starter
Different position. It's in the slot closer to the neck. All the other ones are further back
post #10 of 10 (permalink) Old 11-10-2009, 10:10 PM
Intonate it.
Rich is offline
fine tuner , jem7bsb , string lock screw
egde pro 2 ...fine tuner problem! livfstdieyoung Tech: Setup, Repairs and Mods 5 01-13-2009 01:56 PM
fine tuner problem livfstdieyoung Tech: Setup, Repairs and Mods 3 06-21-2008 10:33 AM
Problem with low-E fine tuner on Edge trem stratoskier Tech: Setup, Repairs and Mods 5 12-28-2007 05:18 PM
edge pro fine tuner problem arnab Tech: Setup, Repairs and Mods 23 08-31-2007 04:45 AM
limited range on fine tuner (edge trem) lemongrass Tech: Setup, Repairs and Mods 4 03-20-2004 07:51 AM
