Fine Tuner Screw - Lo Pro Edge - Jemsite
post #1 of 8 (permalink) Old 06-30-2017, 08:51 AM Thread Starter
Hi Guys,
I neew help with 2 questions:
1.- How Can I remove a fine tuner from my Lo Pro Edge Tremolo? Fine tuner has a plastic ring in the bottom... so... it's not possible remove it. Check first picture.
2.- How Can I remove a fine tuner broken?
Daniel1977 is offline
post #2 of 8 (permalink) Old 06-30-2017, 11:03 AM
Reviews: 6
Re: Fine Tuner Screw - Lo Pro Edge
I don't see any picture on your post
satch_jr is offline
post #3 of 8 (permalink) Old 06-30-2017, 11:17 AM
webmaestro's Avatar
Originally Posted by Daniel1977 View Post
Hi Guys,
I've had to replace one of these screws and yes, there's a little plastic clip underneath that prevents the screw from backing all the way out. Unfortunately, this was many years ago so I don't remember exactly how I did it, so forgive me for the lack of details...
You can clip that little plastic retainer off (which means you have to destroy it), and the tuner will come out. However, to my knowledge you can't put that clip back on, so once you replace with a new fine-tuner screw, you just have to be careful not to accidentally back the screw all the way out. When I did it, I think I used either wire-cutters or a pair of fingernail clippers to clip the plastic retainer. It's pretty easy, actually.
webmaestro is offline
post #4 of 8 (permalink) Old 06-30-2017, 01:06 PM Thread Starter
Thanks for you answer! Sorry, I couldn't upload the picture from my phone... I will try later.
I'm fixing the issue but How can I get the new plastic ring of the fine tuner screw? It's possible to buy? Where?
post #5 of 8 (permalink) Old 06-30-2017, 02:07 PM
webmaestro's Avatar
No, once it's gone it's gone, and can't be replaced (as far as I know). That's why, once you have your new tuner in, you have to always be careful not to accidentally unscrew your fine tuner all the way when tuning, but it's not really a huge issue.
post #6 of 8 (permalink) Old 06-30-2017, 02:14 PM Thread Starter
thanks!!
post #7 of 8 (permalink) Old 06-30-2017, 05:14 PM
They can be replaced but were never needed and a waste of over engineering.
Rich is offline
post #8 of 8 (permalink) Old 07-02-2017, 01:57 PM
webmaestro's Avatar
^ Listen to this man. He's the one who originally helped me with this exact issue years ago--and told me about removing that little plastic clip.
Lo Pro Edge - Bent Fine Tuner... Fixable? webmaestro Tech: Setup, Repairs and Mods 3 04-04-2013 11:32 PM
Stripped screw/fine tuner issue. JEM cpelaez Ibanez JEM, UV, JS & Other Signature Models 6 10-08-2012 12:17 PM
Edge 3 fine tuner out? thehungryhippo Tech: Setup, Repairs and Mods 2 07-11-2010 11:23 AM
Fine tuner problem on Edge Lo Pro Lifeson22 Tech: Setup, Repairs and Mods 9 11-10-2009 10:10 PM
edge pro fine tuner problem arnab Tech: Setup, Repairs and Mods 23 08-31-2007 04:45 AM
