Fingerboard separation at first fret - Jemsite
post #1 of 3 (permalink) Old 07-09-2004, 03:55 PM Thread Starter
My BC Rich Bich has the fret board separated from the neck along the first fret on the low E side. I can fit a razorblade between the neck and fingerboard with some room to spare. Can I just shoot some glue between the joint and clamp it or is it much more detailed work that I'm gonna have to spend some major money?
Thanx,
Peter
lhrocker is offline
post #2 of 3 (permalink) Old 07-09-2004, 10:18 PM
Peter,
Get your hands on a syringe and some good wood glue, the yellow carpenters glue is what I use, (titebond)
You want to get enough glue in there than when you clamp it, the glue squeezes out. Another trick I've used if no syringe is available or if the crack is to small to fit a needle into, is to thin some of the glue, put it into a plastic baggie, let it all sit in one corner, then cut the opposite corner off, slide the baggie into the crack and squeeze the glue out of the cut corner into the crack.
Clamp it tight and let it dry. You should be fine, wipe away the excess glue while it's wet and you won't have to do anything else. Chances are good you won't even need to dress any of the frets if it didn't buzz before the crack started.
Jeremy
littlegreenman is offline
post #3 of 3 (permalink) Old 07-09-2004, 11:08 PM
I like spreading it and using a piece of mylar to work the glue in. Same principle as this exept I'd use a wedge to open the gap up.
http://www.ibanezrules.com/tech/setup/crack_neck.htm
Rich is offline
fret board
truss rod: checking bow at 16th fret or 24th fret? abstract_noise Tech: Setup, Repairs and Mods 0 04-16-2014 12:55 AM
Signal chain Separation/FX Loop HELP NEEDED!!! keysofapollo Gear, Equipment, Recording & Off Topic 0 10-12-2009 03:17 AM
Wish my J Custom had fret inlays on the fingerboard :( & a few other JC questions !! IbanezFreak777 All Other Guitars (including Prestige) 13 03-24-2008 03:29 PM
Jem 777 fretboard separation from neck - Need help to repair hendjo1 Ibanez JEM, UV, JS & Other Signature Models 5 08-28-2001 11:54 AM
