fitting or replacing a neck - Jemsite
post #1 of 9 (permalink) Old 02-17-2012, 05:29 AM Thread Starter
Hi, I have a guitar building project on the go.
I bought a mahogany iceman/destroyer body and plan to use some stuff off my old jem555 with it.
Most stuff will be new except edge pro 2 bridge and the wizard ii neck(for the time being).
Its going great. its fuc**ng gorgeous. im just really unsure if there is a good and bad way to fit the old neck. Is it as simple as screwing it on the new body or should more steps and care be taken first. Im most concerned about neck angle and alignment and any potential damage i could do if im a dumbass, cheers guys for any support.
stevelethal is offline
post #2 of 9 (permalink) Old 02-17-2012, 08:10 AM
Re: fitting or replacing a neck
well, you just have to screw it on. You may use some paper and tape to adjust the neck angle if you have to, but otherwise you should be fine.
TheFreak777 is offline
post #3 of 9 (permalink) Old 02-17-2012, 11:15 AM Thread Starter
Cheers. I thought so. Just sounded too easy tho.
post #4 of 9 (permalink) Old 02-17-2012, 06:18 PM
Reviews: 34
As long as the holes line up and the scale length etc is correct then it is that simple, with shimming etc to get the best action.
nickcoumbe is offline
post #5 of 9 (permalink) Old 02-17-2012, 07:17 PM Thread Starter
Yeah ok. The neck is off a jem 555 and the body is a replacement to fit wizard and Jem profile necks. If the holes line up then the scale length should be correct i guess. Any advice on shimming . Oh and how deep should the neck pocket be. I feel the neck sits a little high over the body but I'm bot sure tbh. I guess if it is a little high them the bridge would just need to be raised to accommodate it?
post #6 of 9 (permalink) Old 02-18-2012, 03:24 AM
19mm pocket .
Zoot is offline
post #7 of 9 (permalink) Old 02-18-2012, 05:52 AM Thread Starter
Originally Posted by Zoot View Post
19mm pocket .
Cheers Zoot. any advice on shims?
post #8 of 9 (permalink) Old 02-18-2012, 12:25 PM
RGTFanatic's Avatar
Each guitars need for shims is different. The only way to know what shims you need (if any) is to put it together, set it up, and play. You'll then be able to evaluate the action/playability.
RGTFanatic is offline
post #9 of 9 (permalink) Old 02-18-2012, 02:36 PM Thread Starter
I kinda thought that would be the case. but was hoping there'd be a more Dumbass proof, txt book method. One thing I can do is make sure the neck pocket is 19mm deep first. Cheers for all your help guys. I'm new here so thanks for making me feel welcome!
alignment , angle , fitting , neck , replacement
Fitting a JS1000 neck to a JS100 body? clar-v-d Ibanez JEM, UV, JS & Other Signature Models 22 06-24-2013 08:54 PM
tips for replacing and fitting a different neck stevelethal Archived Topics and Common Questions 0 02-16-2012 11:23 AM
Ibanez neck thru fitting Reaper121088 Tech: Setup, Repairs and Mods 10 11-29-2011 05:13 PM
Fitting a Prestige neck into old AANJ body Bennelsonlim Tech: Setup, Repairs and Mods 57 11-05-2011 12:12 PM
Fitting a locking nut to a neck TequilaKing Tech: Setup, Repairs and Mods 2 08-02-2007 12:28 PM
