Fixing dings in neck? - Jemsite
post #1 of 8 (permalink) Old 05-19-2015, 12:32 PM Thread Starter
Picked up a well used RG3120 this weekend and there are a few small dings in the back of the neck. I was going to do the whole 600 grit -> 1000 grit -> Gun wax treatment to it but then I came across the wet cloth and soldering iron method... has anyone done this before? Any other recommendations? Here's a pic of the neck but it was a little hard to show the dings. There are a few more than you can see here:
This thing was filthy, but after a thorough cleaning and adjustment it plays so nice. Once I smooth out the neck it will be perfect.
Burtallica is offline
post #2 of 8 (permalink) Old 05-19-2015, 03:58 PM
Re: Fixing dings in neck?
How about applying some wood putty maple-colored locally and then a layer of thin clear coat over it? I had read about the wet cloth + soldering iron method, You wouldn't want to add humidity to your neck, don't know, sounds scary.
panix is offline
post #3 of 8 (permalink) Old 05-19-2015, 04:03 PM
You can only steam bare wood. You wet it first then apply steam to swell the compression back out. You cannot penetrate the clearcoat on the neck. You can fill with superglue and sand back flush if they bother you that much.
Rich is offline
post #4 of 8 (permalink) Old 05-19-2015, 08:18 PM
RGTFanatic's Avatar
THIS^^^^
At best, steaming over the clear will do nothing- at worst it will soften the clear and turn your neck into a gooey mess. If none of the dinks are worse than you pictured, I'd do nothing and play it as it is. If they REALLY bother you- drop filling (exactly as Rich posted) is your best bet.
RGTFanatic is offline
post #5 of 8 (permalink) Old 05-19-2015, 08:33 PM Thread Starter
Thanks everyone. They don't really affect playability at all, I guess I'm just a bit anal about wanting to keep my stuff looking nice.
post #6 of 8 (permalink) Old 05-19-2015, 08:45 PM
RGTFanatic's Avatar
Trust me when I say this- If those are the worst of the dinks.....it DOES look nice!!!
.....and I'm not even putting a smiley after that because I'm serious. Don't mess with it unless you HAVE to.
post #7 of 8 (permalink) Old 05-19-2015, 09:47 PM
yep this is the easiest most effective method. this one works great
https://www.youtube.com/watch?v=rTVScFJoe24
You can get up to 5000 grit at most automotive stores and while you are there pick up some Meguiar's Ultimate Compound. You can use it to get a high gloss finish if you don't have a buffing wheel.
j.arledge is offline
post #8 of 8 (permalink) Old 05-20-2015, 01:13 AM Thread Starter
It's worse than it looks in the photo but I'm having a real hard time getting a good pic of it. That being said, I'm going to heed your advice and leave well enough alone. I don't want to ruin a perfectly good neck because of vanity.
rg3120 neck ding
Patching Dings in an RG570 hlwaller All Other Guitars (including Prestige) 3 05-04-2013 10:27 AM
Show us your Jem dings and cracks! Ad_Astra Ibanez JEM, UV, JS & Other Signature Models 57 03-19-2009 04:31 AM
Fixing neck scratches bnosam Tech: Setup, Repairs and Mods 7 12-27-2008 08:16 PM
Small neck repair - Slight dings and knocks. Maiu Tech: Setup, Repairs and Mods 2 03-13-2006 11:48 AM
Fixing holes and dings? gtrcollectr Tech: Setup, Repairs and Mods 5 03-22-2003 02:33 AM
