Fixing oval hole on a RG550 ('94) - Jemsite
post #1 of 6 (permalink) Old 04-07-2004, 06:29 AM Thread Starter
Hello!
I'm trying to fix a RG 550 LTD with an oval hole where the upper stud is inserted.
The stud is moving and the guitar gets terrible out of tune and is unplayable.
Any idea to fix this? or do the guitar need some new piece of wood in the whammy area?
Tony
tony777 is offline
post #2 of 6 (permalink) Old 04-07-2004, 10:34 AM
if you're a DIY guy that would be easy enough.
you should pull the stud anchor off the body, drill a 17mm diameter hole and flip a 17mm diameter dowel in with some glue, then re-drill a new hole for the stud anchor. it needs some precision.
or you can bring it to a pro.
nuno is offline
post #3 of 6 (permalink) Old 04-07-2004, 04:50 PM
Its a fix most people i know would consider major
sniperfrommars1 is offline
post #4 of 6 (permalink) Old 04-08-2004, 08:50 AM
Tony, Just quickly, Drilling the Hole out and dowelling is really the only obvious way to do it, I have known people to use filler but it only takes a few weeks before the post shifts again ...
Get a competant luthier to do the job, Anyone that installs trems should be able to do it, If you get stuck, Ship to me (get the shipping) and i'll fix her up, I hate seeing people in a bind
Regards
Rob
Jem7RB MK is offline
post #5 of 6 (permalink) Old 04-09-2004, 06:33 AM Thread Starter
Regards
Rob
Thanks Rob!
it's a friend of mine's guitar, and I think he'll go to a luthier, if not I will consider your offer.
Anyway, thanks for your offer Rob.
Tony
tony777 is offline
post #6 of 6 (permalink) Old 04-09-2004, 12:34 PM
No problem Tony, You know where i am :-)
Rob
FS: Eastman AR604CE Oval Hole Archtop Guitar out of control room Classified Ads: Guitars and Gear 1 09-21-2010 11:21 AM
Project Strat repaint. F-hole or no f-hole? skins345669 Tech: Setup, Repairs and Mods 14 02-17-2009 03:41 PM
chambered/hollowbody maple top: hole or no-hole? rbjammin Tech: Setup, Repairs and Mods 2 06-28-2007 12:52 PM
I need some help fixing up my JEM 555... Megadeth7684 Ibanez JEM, UV, JS & Other Signature Models 17 11-04-2005 04:57 PM
